Foundation bracing
| Posted in General Discussion on September 4, 1999 06:14am
I’m subcontracting the construction of a new home 100%. Who would be responsible to brace the foundation walls prior to backfill?
  1. Guest_ | Sep 01, 1999 03:31am | #1
    Hi Daron,
    Whoever you stipulated in your contract agreements.
    Gabe
    1. Guest_ | Sep 01, 1999 05:47am | #2
      *daron...dont know why... but it usually falls into my lap.. being the framing subcontractor... usually charge about $300 to do it... and worry like a son of a gun... until i get the subfloor on... you know liability for wall falling in due to a stupid dirt contractor who backfills with mud!!!E
      1. Guest_ | Sep 03, 1999 03:38pm | #3
        *If you dont know ask yourself, Should I be doing this?
  2. G.LaLonde | Sep 03, 1999 04:18pm | #4
    Daron, Save yourself a lot of grief and worry...Pour the floor while it is easy to get at and then install the floor deck before you backfill.
  3. Daron | Sep 04, 1999 06:14am | #5
    I'm subcontracting the construction of a new home 100%. Who would be responsible to brace the foundation walls prior to backfill?
  4. Guest_ | Sep 04, 1999 06:14am | #6
    Daron,
    In nothern Illinois the county requires bracing and it falls
    upon the concrete sub to provide it. Being motivated to avoid problems/$ he will definitley pour the basement floor first (he also decreases his manhours with this method),and will add 2 #4
    rebar at top of wall. Installing the deck is excellent bracing if you can talk the framers into it. Without it bracing every 20 foot is adequate. The best thing you can do is be on site when it is backfilled. If the operator is exhibing any disregard, bring out the camcorder. It's your show. You cut the checks!
    Good Luck, Rick
  • A Grand Rescue on the Coast
