foundation has the slope
vincent843 | Posted in Construction Techniques on October 31, 2011 11:14am
Hi everyone,
I want to build a little shed 8×10 in the back yard, but have to deal with the slope foundation.
So left side of the shed the rafters are  higher than the right rafters side 1/2 “.  Would I build all the walls equal
length ( 8′ tall), then on the right walls I added 1/2 ” plywood on top before adding the rafters.
Thanks,
Vinh
  1. calvin | Oct 31, 2011 08:44pm | #1
    Vincent.
    Touigh answer.
    If the walls etc are not built yet, then make the foundation level.
    If the floor and walls are up, sure-why not.  Remember to figure your siding from the top down-(you don't have to install it top/down, but make it end up right when you get up there.
    Best of luck.
    1. vincent843 | Nov 01, 2011 03:53pm | #4
      Nothing has built yet, except the foundation is there. But bski make me thinking, can you really tell if the house is off  1/2"?
  2. bski | Oct 31, 2011 10:49pm | #2
    You could just build it the way it sits taking care to make the walls square.
  3. DanH | Oct 31, 2011 11:30pm | #3
    You could, of course, cut lumber to make the roof level, but if you want to use precuts then the plywood on top of the top plate is probably the most reasonable approach.  For 1/2" you pretty much have to use plywood, and you wouldn't want plywood (unless it's foundation grade) on the slab, nor between stud and plate.  Do put rafter ties on the rafters, though, as toenailing through the plywood will not be terribly secure.
    Like someone else said, think about your siding (if you're using something with a horizontal pattern) to be sure it will match up .
  4. cussnu2 | Nov 01, 2011 04:26pm | #5
    It would be a heck of a lot easier to level the foundation and build from that than it would be to try to adjust it at some point in the future.  If it truly is 1/2" then a strip of Pressure Treated 1/2" plywood on the low side should solve the issue.
Versatile Vise
