Foundation insulation & exterior finish
DragoonCreek | Posted in General Discussion on July 29, 2003 05:28am
Hi All,  I did a quick search on this but couldn’t find good info.  I just did some minor drainange and foundation work.  Now I want to insulate the crawl space AND select a material to cover the outside.
I will need a General Contractor for this minor job, but need some ideas on what to ask him/her to do:  EPS on the outside or inside.  If outside what recommendations for exterior finish, etc?  I had leakage and settling due to grade and ext finish materials allowing water to seep back into the foundation.  What is a good product to attach to the EPS, or should I just stick with interior foam and use a stucco or other venier (sp?) product.
Thanks in advance, the replies on two previous postings have been a great help when discussing issues with local contractors.
  1. Bruce | Aug 01, 2003 03:54am | #1
    My choice would be to go with 2" blue foam and then Grailcoat for the exterior finish.
    http://www.grailcoat.com
    Formerly BEMW at The High Desert Group LLC
    1. DragoonCreek | Aug 01, 2003 07:06am | #2
      Thanks for the response Bruce, I will check out grail coat!
A Practical Perfect Wall
  • The New Old Colonial
