Hello, I am trying to find a DIY solution to a slightly bowed concrete block foundation. I had a foundation guy there and he said I was unable to use the wall anchor system that goes into the soil because of the proximity of the neighbor. But he did have another system that would cost me $3100. Is there a system that can be sold to me directly? Is there a low tech solution? I am trying to sell my home so I need to make the buyer feel super confident with my solution.
Any advice would be greatly appreciated,
David Brown
Tips for protecting your personal information when using Wi-Fi-connected devices.
There is a simple low tech system.
It is I-beams that go from a pocket in the floor to bracing attached to the joist.
But you will need to get an engineer to spec it.
JLC has an article on it about 3-4 years ago.
http://www.jlconline.com
Then Research and look it up.
They charge a few bucks for the articles.
Remove the wall and replace, with rebar and concrete in every 2nd/3rd core. Backfill with pea gravel.
No electrons were harmed in the making of this post.
you must be very close to your neighbor for them not to be able to install the anchors.
I have them in my walls and I think the rods are 9'-0 long if I am not mistaken.
What was the other method the foundation contractor suggested?
