Foundation vent double as a dryer vent?
mwgaines | Posted in General Discussion on May 11, 2007 04:20am
I just had brick veneer installed on the one-story house that I’m remodeling. I thought I covered all the bases during the rough-in, but now I realize that I forgot to provide a 4″ hole for the dryer vent. It just so happens that one of the foundation vents sits directly below the room where the dryer will be located. Is there a way that I can allow that foundation vent to double as a dryer vent so I won’t have to create a large hole in my brand new bricks?
New knowledge is priceless.
Used knowledge is even more valuable.
  1. dovetail97128 | May 11, 2007 08:24pm | #1
    mwgaines,
    I have done just that .
    Check to ensure you have adequate venting to start with though.
    I cut the screen out of the foundation vent (one siee only if a double vent) fab a piece of sheet metal to fit the opening then cut a 4" diameter hole in the sheet metal for the dryer vent to exit through, use a standard dryer vent cap to finish .
    "Poor is not the person who has too little, but the person who craves more."...Seneca
    1. JohnT8 | May 11, 2007 09:19pm | #2
      Some of the companies that make glass block also make accessories that can be used with the block, including dryer vents.  IIRC, one of our local Menards carried little windows and dryer vent setups that were designed to be 2 glass-blocks wide, which is the same dimension as the vent holes on my crawlspace.
      So if someone didn't want to fabricate their own vent, they might be able to buy one of those dryer vent setups.
      In my case, they cemented the old metal vents into the vent holes, so even though the hole itself is the right size, the crete they slapped in to hold the old vents will need to be removed before I can either replace the vent or stick in a premade dryer vent.
      "One of the true tests of leadership is the ability to recognize a problem before it becomes an emergency." -- Arnold H. Glasgow
    rjw | May 12, 2007 12:28am | #3
    Checkout the Building Science site http://www.buildingscience.com/bsc/ and decide whether you really want to vent the crawlspace in the first place.
    Whatever you do, do NOT vent the dryer into the crawl and expect the crawl space vent to then take care of things.
    With my mouth I will give great thanks to the Lord; I will praise Him in the midst of the throng. For He stands at the right hand of the needy, to save them from those who would condemn them to death.
    - Psalms 109:30-31
