A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
When installing pipe or conduit through a masonry wall:
a. It must pass through a sleeve. This is typically a galvanized pipe - NOT tubing - min 1/2" larger in diameter.
b. Depending on pipe size, they make sealing gaskets for inside the sleeve. Otherwise use expanding foam. Apply expanding foam as close to the wet side of the wall as possible, if applicable.
c. Sleeve should be encased in hydraulic cement to bond it to the masonry wall.
d. Limit it to 1 pipe per sleeve.
e. Generally 6" separation for sleeves 2" or less.
Frankie
thanks for the info Frankie. very helpful
what about minimum distances from edges? same 6" rule apply?
thanks again
