frame and thick panel expansion
jptort | Posted in Construction Techniques on August 2, 2007 03:38am
Several articles and books encourage using a 1/2 inch panel instead of a 1/4 inch panel in plain frame-and-panel doors in kitchen cabinets for additional ruggedness and better sound. I like the idea, but wonder how much clearance to leave between the rabbit and the frame on the inside of the door to allow for seasonal movement. I want to paint the completed doors, so will make them from either soft maple or poplar with birch plywood panels. Given all that, is the plywood-to-long-grain seam stable enough that I need 1) no clearance, 2) oh, about 3/16 on each side, or 3) just make them from 1/4 and call it good.
    Sphere | Aug 02, 2007 03:41am | #1
    Plywood panels need no room for expansion. None.
    1. grpphoto | Aug 02, 2007 07:14am | #3
      Yeah, the plywood panels won't expand, but the rails and stiles will just a little. Leave a little room in there (no more than 1/16").George Patterson
  2. FastEddie | Aug 02, 2007 04:23am | #2
    Make the panels from medex and leave just enough tolerance to slide them into the groove.
  3. terryb | Aug 02, 2007 07:31am | #4
    Sphere is right about plywood expansion. However, trying to exactly fit a panel into a frame is a nasty job and will cause you problems. For flat-panel doors I use either 1/4" ply (only at customer request) or 3/8" ply (preferable). But whether the panels are plywood or solid wood I fit them as follows: The groove is 7/16" deep in the frame. The groove width, of course, suits the panel. I make the panel 1/4" smaller in height and width than the hole it's going in and I hold it in place with several pieces of 1/4" or 3/8" backer rod (foam rod used to caulk log homes). The panels don't move around and super precision isn't required. Before assembly, I slightly chamfer both sides of the groove with 100 grit (or so) sandpaper on a wood block. This makes the assembly appear more uniform. Hope this is of some help.
    1. jptort | Aug 02, 2007 05:41pm | #5
      Thanks, all. I think I'll try to find find some 3/8 ply.
