framing a second floor into a balloon…
| Posted in General Discussion on May 27, 2001 09:26am
framing a second floor into a ballooned framed wall
I’m a draftsman here in California who is trying to detail the above described condition. If the joist spacing is the same as the wall stud spacing does it suffice to run cripple studs under each joist and block in between or is there something more straightforward like bridging or letting in a ledger at the wall? This is only happening at a specific location in the house over a stairway. The floor is only spanning about 4′. Any help is appreciated.
  1. Gabe_Martel | May 27, 2001 02:49am | #1
    Any of the above, given that you only have a 4 foot span to support.
    Gabe
    1. Michael_Cobb | May 27, 2001 09:26pm | #2
      *Thanks Gabe
  2. Michael_Cobb | May 27, 2001 09:26pm | #3
    I'm a draftsman here in California who is trying to detail the above described condition. If the joist spacing is the same as the wall stud spacing does it suffice to run cripple studs under each joist and block in between or is there something more straightforward like bridging or letting in a ledger at the wall? This is only happening at a specific location in the house over a stairway. The floor is only spanning about 4'. Any help is appreciated.
