I am having a problem finding an old FHB article and was wondering if someone remembers the issue (I believe it was sometime in the past 2 years). The article highlights a plastic jig which wraps around a round basement pole to aid in boxing in the pole. The product also allowed for wiring to run through the jig. Any thoughts – thanks! |
Construct the intersecting gable on the main roof for a faster, easier-to-build assembly.
Hi Lizzy,
It's called the EZ Column - you can buy them through http://www.mcfeelys.com
Justin Fink - FHB Editorial
Your Friendly Neighborhood Moderator
thank you so much!!
Do you happen to remember which issue had a short article about the product. I have all my back issues, but can not find it? thanks again.
Houses issue #179Justin Fink - FHB Editorial
