I am building my own home and just getting ready to start framing. I plan on putting my sheathing on before standing up the walls. I was also considering installing my windows before standing the walls up. Do you think it is a good or bad idea to install the windows prior to standing up the walls?
Listeners write in about deepening foundations and ask questions about HRVs, smoothing rough concrete, and finding the right workwear.
Video: Build a Fireplace, Brick by BrickRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
Joel, it depends. Get someone with experience to help you. Be safe!
*I never, ever put windows in until the roof is on. If a ladder slips, or something is dropped, you can spend a bunch of money real quick. If you want to leave the house closed up, cover the windows with your shething and cut them out with a sawzall later.
*Yeah Joel,Put the windows in later. Too many opportunities for breakage, as Boss said.
*Yeah, but, I've installed around a hundred or so while walls are flat, and haven't broken one. If the hole is going to be way, way up in the air, then the window in first might not be a bad idea. Especially if it's a picture window. I'll take part of that first sentence back. I did let a saw roll off the roof while being a dumbass apprentice. It shot off the roof, the cord came tight, and it swung back and right through a priceless vinyl single-hung. Better be careful, like the old-timers above said.
*I have run a framing crew for twenty years and would never dream of putting windows in while the wall was down except for maybe an attic window if I was going to side the wall while down as well. Being able to pass materials through these openings is essential. Climbing in and out onto staging for exterior trim, ect.. not to mention breakage.
*Another thing is I don't like the windows exposed to weather on their inside surfaces. Brings a new meaning to "stain grade". Probably wouldn't matter if they weren't wood on this side though.
*The only time I've put them on is when we are using T1-11 without any window trim(lowend houses). We never did break any.Dave
