Framing floor to ceiling windows?
Dodoak | Posted in Construction Techniques on July 9, 2015 10:42am
Hi everyone! We are designing a modern house and looking to have our windows meet the wall corner at the ceiling. I think we can strap the header to the plate, but where does the plate go? I can’t visualize this. Any details out there?  I may have to let the engineer figure it out,  but I wanted to understand it first.
Can all of these architects be dropping the ceiling.
Thanks!
  1. quicksilver | Jul 09, 2015 06:04pm | #1
    If I am following ou I
    If I am following you correctly I suggest you double up the rim joists having them act as headers and as top plates where necessary.  If you are going to be able to put a post in the corner the configuration won't be far from typical. If you plan on a glass to glass corner then you'll need to cantilever both doubled rim joists.
      deadnuts | Jul 09, 2015 11:21pm | #2
      A clear case of the blind leading the blind.
      1. mark122 | Jul 10, 2015 07:22pm | #6
        And a clearer case of a dip shit who doesnt seem to realize hes the joke of the town.
        Yes let your engineer do what he does. Only time I have been involved with floor to ceiling glass in a residential application there was a considerable amount of steel work done during the framing stage that was wrapped in break metal matching the frames. you get much more involved with frameless walls.
        1. quicksilver | Jul 10, 2015 08:23pm | #7
          A
        2. quicksilver | Jul 10, 2015 08:29pm | #8
          A
  2. DanH | Jul 10, 2015 07:32am | #3
    If you want windows all the way to the ceiling (or within 2-3 inches of it) and don't want a dropped ceiling then you need an engineer.
      deadnuts | Jul 10, 2015 07:49am | #4
      Dan's on the right track
      However, let me make this even simpler:
      If your building district requires building plan reviews for permit and the framing for your modern house does not follow prescriptive building code, then you need an engineer.
  3. florida | Jul 10, 2015 01:22pm | #5
    Are they going to be fixed glass or a window that opens?
