framing for chimney
joroslo | Posted in Construction Techniques on June 29, 2014 11:19am
is there a standard size that i need to make the whole in front of the fireplace ?
  1. oldhand | Jun 29, 2014 07:10pm | #1
    short answer is...
    No.
    If you have a plan it should be there. If you don't maybe you need to consult the mason if it's a true custom job or the manufacturer if it is some form of prefab.
    I figure some heads will explode on this forum if you don't have a real set o' blue prints. Not mine.
  2. oops | Jun 29, 2014 08:43pm | #2
    The size of the fireplace opening directly effects the size of the damper and the flue tile / chimney.  Google fireplace design.
    1. joroslo | Jun 29, 2014 08:56pm | #3
      thank you i will try that. i have a floor plan but it does not give those measurements. just trying to find out if there is a minimum size for yhe hole in the floor and for the header in the wall
A New Approach to Foundations
