Framing for skylights in an old roof
Framing for skylights in an existing roof, is doubling up of the existing rafters required? Or is it sufficient just to head off the opening?
In this FHB Podcast Segment, the team chats about the best way to build a paintable surface over an old wall.
Will you be cutting out sections of existing rafters or will the
skylights fit between two of the existing rafters? If you are not cutting any of the existing rafters, you should only need to add headers.
