I just purchased a Max Sn890Rh Framing nailer on the advice of FHB magazine. Is it neccessary to use 3/8″ fittings to obtain full power from the nailer? All of my present tools have 1/4″ fiitings. Is it worth the switch? I cuurently use 50 and 100′ 3/8″ hose with 1/4″ fittings. Is 100′ too long of a hose? Thank you
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
No problem with a 1/4" fitting, it's 1/4" hose that will slow things down. Joe H
*Liberty I believe it's better to run a longer hose than run your compressor on a longer cord.Dave
*You can run hose really long if you want to. There's no real loss due to friction or any thing. It's just like a water pipe. Like Joe says, a smaller dia. will decrease the volume available at the receiving end. 1/4" dia. is no problem for finish guns, but for sheathing, roofing, framing, etc. can be an issue. -Ken
I run almost all 1/4" hoses. It adversly affects my staplers in cold weather.
blue
It's definetly better to run a long hose rather than a long extension cord on the compressor. Big hose is best to avoid pressure loss, but it's lack of flex makes the nailer hard to handle. I have a 15 foot section of 1/4 hose on the end of the longheavy to get the best of both worlds.
