Framing Nailers–Paper or Plastic
| Posted in Tools for Home Building on July 19, 2007 07:04am
I expect to have to build a deck and possibly a shop when I move in the next year or so and because I have to replace a porch on my current house I thought I’d get a framing nailer now.  I am considering one of the Bostitch framers that has an attachment to allow it to handle metal connector nails in addition to the normal framing nails.  They offer two versions: one that uses 33-degree, paper-collated nails and one that uses 22-degree, plastic-collated nails.  Question one: is there an advantage to one method of collation over the other?  I’ve read that the plastic ones sometimes suffer from flagging, i.e. leaving pieces of plastic stuck under the nail-head.  This would be a problem on visible surfaces, such as railings and decking, wouldn’t it?   How big of a problem?  On the other hand, plastic-collated nails seem to be more readily available in the local big boxes.   Question two: is one angle significantly better than the other?   Thanks.
Tom
  1. JTC1 | Jul 19, 2007 02:38pm | #1
    Welcome to Breaktime!  You've been lurking a long time.
    I cannot speak to the Bostich nailer or the viability of the metal connector nailing attachment as I have no direct experience.
    I have a Hitachi framer and a Bostich palm nailer which I use for the metal connectors.
    Your questions: paper vs plastic collation - I think only clipped head nails use paper collation (and some Paslode "RoundDrive"?), full round head nails use plastic. The collation techniques doesn't really matter. Paper is more compact. So the nail head style becomes the real issue - full round heads can be used anywhere, clipped head use is restricted in some building codes. My opinion is that exposed clipped head nails look nasty - deck and rail consideration for you.
    flagging - yes it is unsightly on an exposed surface. The plastic can usually be removed from a "just set flush" nail with fingers, knife point, or needle nose pliers. Not a big deal.
    >> plastic-collated nails seem to be more readily available << - this is probably the most important consideration for you - the nailer won't help much if you cannot get the nails you need.
    Collation angle - no big difference as far as I know. 33 degree collation will mount the nail magazine to the nailer at a sharper angle which would allow the nailer to get into a tighter opening.  Hitachi is 22 degree and usually will fit where it is needed - if not I use the palm nailer or a hammer for those few places the nailer won't fit.
    Others will chime in soon.
    Jim
    Edited 7/19/2007 7:39 am ET by JTC1
  2. MikeHennessy | Jul 19, 2007 03:24pm | #2
    Ease of picking up the fasteners locally is a major deciding factor. I've never had any problems with any collation method, just problems picking up nails. It's a royal pain to have to order online when they have cartons of nails in the local stores that are fine, but they won't fit your gun.
    Oh, now that I think of it, there is one collation issue that I've dealt with. Plastic collated coil nails for my Max tend to pop out of the plastic "belt" if you don't handle them with extreme care in storage and loading -- causes feeding to come to an abrupt halt until you remove the offending section. Minor issue, but an issue just the same.
    Mike Hennessy
    Pittsburgh, PA
    1. DanteO | Jul 19, 2007 06:39pm | #5
      Hartman Independent Co. on Mayview Road probably sells the nails you need since they are a large Nail supplier and also a Max Dealer.
      1. MikeHennessy | Jul 19, 2007 07:03pm | #6
        VERY cool. Thanks! Never used them, but I'll look 'em up. (They are nearby, too.)
        Mike HennessyPittsburgh, PA
        1. TJW | Jul 19, 2007 08:24pm | #7
          All:
          Thanks for the info.  I think plastic wins out.  If flagging isn't so bad I can live with it, and nail availability is important.   Regarding round vs. clipped heads, both the Bostitch's I'm looking at, the F21PL and the F33PT, use round-head nails.  The F21PL uses plastic and the F33PT uses paper.  Thanks again.
          Tom
            BillHartmann | Jul 20, 2007 12:14am | #10
            I was wondering what you was talking about becuase I had only heard
            about the N88RHhttp://www.bostitch.com/default.asp?CATEGORY=BOS%5FFRAM%5FNAILER&TYPE=PRODUCT&PARTNUMBER=N88RH-2MCN&SDesc=Industrial+Round+Head+Framing+SystemBut it looks like they have come out with two new ones.http://www.bostitch.com/default.asp?CATEGORY=BOS_FRAM_NAILER&TYPE=PRODUCT&PARTNUMBER=F21PL&SDesc=21%26%23176%3B+Industrial+Framing+Nailer+System
            http://www.bostitch.com/default.asp?CATEGORY=BOS_NEW_PRODUCTS&TYPE=PRODUCT&PARTNUMBER=F33PT&SDesc=Paper+Tape+Framing+Nailer
  3. FastEddie | Jul 19, 2007 03:41pm | #3
    Call the local building inspector and ask if they allow clipped head framing nails.  Regardless of what people say about holding power and such, it's his call.  Some places require full head nails, and that might sway your decision.
  4. catfish | Jul 19, 2007 03:43pm | #4
    the little plastic pieces will shoot all over when using plastic collated nails.  Especially in tight quarters.
  5. craigf | Jul 19, 2007 08:43pm | #8
    If you get plastic be sure and wear eye protection. I have a bostitch and will sting ya pretty good with a stray chunk of plastic every once in awhile
    1. TJW | Jul 19, 2007 10:12pm | #9
      Craig:
      That's good info to know. Thanks, I'll remember do that.
      Tom
