Here’s one that has me stumped. I am getting ready to start building a 24×32 2 car garage with an apartment above it. I will be setting up a shop in the garage, but I don’t want to heat it all the time. How can I run the water supply to the apartment without having the pipes freeze. So far the only solution that I have come up with is to build a heated mechanical room outside below the stairs and run the water up through the slab at that point. This would also give me a spot to set up a slop sink,washer dryer and the HWH.The apartment will be heated by a monitor heater and a woodstove, so what would be the best way to heat the mechanical room?Also do the 4″waste lines need to be freeze protected, or just the traps? any insight will be appreciated.Thanx Scott
![](https://images.finehomebuilding.com/app/uploads/2024/08/13141923/FHB-IRA-23-Tax-Credits-Claims-Feature-thumb-16x9.jpg)
Discover how American families can benefit from Inflation Reduction Act–enhanced tax credits.
scott...sounds like yur on the right track...
where do you live.. what temps can you expect outside?
will the mech room be inside the garage space?.. i don't know whether u got the stairs runnin up the outside or the inside?
*Mike, I live over on the Vineyard, not too far from your neck of the woods. I was hoping to keep the stairs outside running up to a 10x24 deck. This building will only be about 100' from my house which is 36x28 so I am trying to keep the new structure a little smaller for the sake of proportion.Hey are you going to go to the JLC show in Providence? I always say I'm going to go, but I haven't made it yet. Scott
*scott.it doesn't take much heat in a well insulated enclosure to protect the plumbing...but it only takes a little draft to defeat it, are all of your heat sources combustion type or wud u think of small electric..can u count on the Vineyard elec supply?a 4 inch waste with the proper pitch shud not be a problem.. but u have to get yur traps into the heated zone..like i said.. i tgot all the bases coveredh, just allow room for insulation on the cold side ... and access for the heat to protect eh plumbing on the warm side...see u at JLC, be there or be square
