Freezer crack filler
freezer_boy1 | Posted in General Discussion on December 23, 2020 02:04pm
I’m getting ready to paint an indoor freezer, looking for some type of wood filler that will stand up to -20°, or putty
  1. florida | Dec 23, 2020 02:52pm | #1
    Why wood filler? There are surely much better choices like epoxies. How about JB Weld?
  2. oldhand | Dec 24, 2020 06:45pm | #2
    You might also consider bondo [auto body filler].
  3. mikemahan3 | Dec 25, 2020 02:05pm | #3
    It sounds like you are painting the inside of the freezer. Either that or you live in a very cold climate and don't heat the indoors. If you are painting the inside, then appearance should not be an issue. Since the inside is undoubtedly plastic just use some solvent based plastic glue to patch the cracks. I assume that the -20 degrees is celsius, since there is no way your freezer will reach -20 farenheit.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
