I’m finishing the floors in an 1885 Victorian. This is the entrance way to the music room:
Ditch
Ditch
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Sure wish you had more pics here. Good stuff
Thanks for the photo Ditch.
I'm in the process of trying to strip paint off a lot of interior woodwork with hopes of staining. Quite a bit of detail, just like the fret work your picture shows.
I'm looking for a good source on techniques to do this without damaging the detail. Any ideas Ditch?
TIA,
Ron
That's some fine stuff , there. What's the rest of the house look like?
Here's some whimsical stuff from the Out Islands in the Bahamas...tried to make it fast to load, but if you can't see the seahorses and fish, I can make it bigger... EliphIno!
Press the attachment button, duh! EliphIno!
