Fridge water—-Copper or Mesh over PEX
etherhuffer | Posted in General Discussion on October 31, 2006 04:52am
When our fridge goes in, should I ask the installer for soft copper or stainless mesh over pex(or tygon or whatever that stuff is)?  Seems to me copper crimps and is more prone to damage. Thoughts?
Those who can make you believe in absurdities can make you commit atrocities- Voltaire
    IMERC | Oct 31, 2006 05:15am | #1
    SS mesh...
    WOW!!! What a Ride!
  2. plumbbill | Oct 31, 2006 05:23am | #2
    No-burst¯ by fluidmaster
    Had a huge problem with vinyl connectors at Lincoln Square.
    When I took over that 42story piece of junk, I found out they were using vinyl, I said no friggin way & ordered up 200 no-burst connectors.
    “It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
    1. etherhuffer | Oct 31, 2006 06:53am | #3
      Thanks! That was my opinion.Those who can make you believe in absurdities can make you commit atrocities- Voltaire
    2. etherhuffer | Oct 31, 2006 06:58am | #4
      Also, what is the best connection from dishwasher to the 1/2 waste line that feeds to a Johnson Tee in the wall?Those who can make you believe in absurdities can make you commit atrocities- Voltaire
      1. plumbbill | Oct 31, 2006 07:01am | #5
        The factory supplied waste hose that comes with the DW.
        If you don't have that, 5/8" ID black automotive heater hose.“It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
  3. DanH | Oct 31, 2006 01:49pm | #6
    At the very least, if plastic is used it must be protected from damage where is passes through the wall or floor and protected from damage due to someone sliding the fridge into it.
    Steel-reenforced hose is probably the best choice, copper after that.
    Seven blunders of the world that lead to violence: wealth without work, pleasure without conscience, knowledge without character, commerce without morality, science without humanity, worship without sacrifice, politics without principle. --Mahatma Gandhi
  4. darrel | Nov 01, 2006 04:53am | #7
    Anything wrong with the plastic kit you get at home depot and the like?
    We just got a new fridge with a ice maker (our first one!...should I really be that excited about it?) and the only thing that they had that wouldn't have taken me all weekend to install was the self-piercing connection with plastic (PVC?) tube. It seemed to install easy enough with no leaks. But it just 'seems' kind of cheap. Should I fear any issues down the road?
      IMERC | Nov 01, 2006 05:17am | #8
      leaks..
      1. darrel | Nov 01, 2006 05:55am | #11
        well...crap...looks like I'll have another job to tackle in the near future... ;o)
    2. edwardh1 | Nov 01, 2006 05:30am | #9
      they will leak. ruined my kitchen vinyl floor. should be illegal.
      use copper.
        IMERC | Nov 01, 2006 06:27am | #14
        copper can kink... break.. flood..
        go with the no-burst and be about as about bullet proof as you can reasonably get..
    3. DanH | Nov 01, 2006 05:33am | #10
      Plastic is too easily damaged, and ages (and becomes brittle) fairly quickly.
    4. PatchogPhil | Nov 01, 2006 05:58am | #12
      Unless you like your chilled water and ice cubes to taste like a new swimming pool liner.....  do not use the pvc.
    5. etherhuffer | Nov 01, 2006 06:00am | #13
      I think the pros have spoken. I bought the braided stainless today. Mind you, rolling  fridge or dropping a washer leg on the stainless is not a good idea. The stainless is a plus for not bursting outward , but they can be crimped if squashed by a heavy object. I have these lines on my old RX7 for brakes and clutch. Nice hose design. But plain old plastic sounds scary. To easy to crimp and hard to connectorize correctly. I had a compression fit plastic line on washing machine. It was not a good design.Those who can make you believe in absurdities can make you commit atrocities- Voltaire
      BillHartmann | Nov 01, 2006 06:34am | #15
      "self-piercing connection "And they have a steel tip that will corrode and clog after a few years.Better ones you remove the needle valve and drill into the pipe.Even better is to add a T.Or you can replace the stop valve with a "dual port" one. Not the best option as it shuts off both the faucet cold water and the frig at the same time, but it is safe and easy to do.BTW, when I replaced my refigerator 2 years ago and ask about deliver even place I talked to said that they would deliver and "install". But because of liability they would not hook up to a plastic water line.
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
  • Natural Simplicity
