Front porch
user-156695 | Posted in Construction Techniques on May 20, 2006 01:29am
What is a good choice of wood or composite decking for covering my front porch? This is a covered porch; however the steps will not be covered. Since I will be laying the product over ¾ plywood on the porch, I would like a tongue and groove product to keep the dirt and debris from collecting between the boards. A couple options I am considering are 1×4 finger jointed cvg, which I will paint or 1 x 4 mahogany. Will these products stay tight or will expansion and contraction cause excessive gaps. I also have left over rift and quartered white oak that I used indoors, would that make a good option? Please suggest any other good options. I live in the Pacific NW.
Thank you, jerry h
  1. Piffin | May 20, 2006 02:51am | #1
    Whoa!
    anything you put down over a plywood subfloor for an exterior deck will be rotting out in a few years so forget that
    CVG Fir is traditional for covered porches
    run it perp to the house for drainage away and seal all edges before putting it down - on the joists!
    1. DougU | May 20, 2006 03:52am | #2
      Piffin
      I agree with you on the adding something over plywood, not a good idea.
      I have a porch floor that needs replaceing back in Iowa and was going to do it with VG fir but then when I read this thread 73915.1 it made ne wonder, what do you think went wrong with this guys floor?
      Is the CVG fir as good as it used to be?
      1. Shep | May 20, 2006 05:06am | #3
        I like Tendura for covered porches.
        Its a composite T & G product that looks good installed.
        I have it on my own front porch- 4 years and absolutely no sign of rot, and the joints are still tight.
      2. Piffin | May 21, 2006 02:12am | #4
        getting harder to fiond real vertical grain. then I have to figure on culling 15% out. That makes Ipe` very competitive
    zachariah | May 21, 2006 04:29am | #5
    ipe is a great product although you are inviting trouble sandwiching any two materials in a potentially wet area with no drainage.
