Frozen exterior p-trap
worksofart | Posted in General Discussion on March 20, 2011 11:45am
I have a post and beam structure built in a flood plain approximately 3 feet above grade that has a 2 inch p-trap drain line for a shower below the insulated area of the house. The drain pipe is insulated with fiberglass pipe wrap and I constructed an insulated 5 gallon bucket over the p-trap, but in this locale that gets down to 5 degrees F ,it has frozen the water in the trap. I lined the inside of the bucket with 2 inches of styro-foam insulation, is this enough or would a different type of insulation be more effective. I looked into heat wrap tape but the manufacturer recommends not for drain pipe use. At this point there isn’t any electric outlet close by.Any ideas?
  1. DaveRicheson | Mar 21, 2011 06:04am | #1
    I looked into heat wrap tape but the manufacturer recommends not for drain pipe use. Any ideas?
    Change the pvc trap to CI or copper, include the drop to the trap and about 2' of waste line on the outlet side of the trap.
    Install heat tape
    The other option is if the trap is schdl 30 or 40 pvc, change it to schedule 80 and use the heat tape.
  2. DanH | Mar 21, 2011 07:15am | #2
    Remove all insulation ON the trap and ABOVE the trap.  Build a box around and below the trap, and insulate that.  Pull the trap into the "envelope".
    If there is a heating duct nearby a well-placed hole or two in the duct can provide a little extra "insurance".
  3. [email protected] | Mar 21, 2011 03:12pm | #3
    Light bulb
    I'd just add a light bulb.
    If your feeling really fancy get a resistor and a thermostat to control it.
    xxPaulCPxx | Mar 21, 2011 03:56pm | #4
    Think the problem with using it on a drain like a toilet is
    1. It could melt the wax seal
    2. it could evaporate out all the water from the trap leading to gas backflow
Fast, Accurate Wall Framing
