GAF asphalt shingles
Taylor70 | Posted in General Discussion on May 3, 2024 07:01pm
I am planning on getting a new roof installed with at least GAF HDZ asphalt shingles.  Considering GAF Ultra HDZ. Then there are the various grades of the other GAF roof components such as ice & snow shield, roof decking barrier, starter shingle, cap shingles, ridge vent.  The home is in Delaware but about 10 to 15 miles from the beach.
How do I know which upgrades are worth it.
  1. Walterbrennan | May 08, 2024 02:49am | #1
    Consider GAF Ultra HDZ shingles for enhanced durability and wind resistance, essential for coastal climates. Adding an ice and water shield is crucial, especially at vulnerable areas like eaves and valleys, to prevent water infiltration. Invest in high-quality roof deck protection to keep shingles flat and protect against moisture. Ensure that starter and cap shingles are high-quality to improve wind resistance and protect ridge vents. Proper ridge venting is also vital for removing excess attic heat and moisture, extending your roof’s lifespan. Consulting with a licensed roofing contractor experienced in coastal properties will help you choose the right options for durability and cost-effectiveness.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
