Galv. + Aluminum Dryer Venting?
Kevin_D | Posted in Construction Techniques on March 28, 2013 08:24am
Hello All,
I have a quick question regarding dryer venting. I wanted  to run my 4″ rigid ducting in galvanized vice aluminum.
The only problem I have run into is that “offset elbows” seem to all be in aluminum. E.g –  http://www.amazon.com/Builders-Best-10162-Venting-Offset/dp/B000DZDPHW
I don’t want to mix metals due to galvanic corrosion. The humid dryer air will likely cause corrosion.  http://www.galvanizeit.org/about-hot-dip-galvanizing/how-long-does-hdg-last/in-contact-with-other-metals
There is contrary information here (saying galvanized may contact aluminum): http://www.eng-tips.com/viewthread.cfm?qid=245894
Is there a supplier of galvanized dryer fittings?
Do you just isolate the metals?
Should I just not worry about it?
Even if I went with aluminum ducting the lint trap and roof vent are galvanized, so disimilar metals would be in contact.
My other option would be to use a regular galv. ducting but that would make the dryer stick out more.
    MarkH | Mar 28, 2013 09:09pm | #1
    Galvanized elbows are more common than aluminum, big box stores have them in the heating area.  I would try to keep the vents all similar metal, but I don't think it matters much.
  2. DanH | Mar 28, 2013 09:24pm | #2
    I wouldn't worry about that one offset elbow.  It goes right behind the dryer, so in 20-30 years, when it finally corrodes through, you can simply pull out the dryer and replace it.
  3. rdesigns | Mar 29, 2013 09:16am | #3
    Don't worry one bit about mixing the two--remember that the standard pipe for venting gas appliances ("B-vent") is a double-wall pipe, aluminum on the inside and galvanized on the outer pipe. They are crimped together on the ends and are in contact with condensation from the combustion gases throughout their life.
Two Ways to Test Windows
  • The New Old Colonial
