Galv. Fittings OK w/ Black Pipe for Gas?
| Posted in Energy, Heating & Insulation on May 17, 2005 09:14am
Peter Hemp’s plumbing book recommended it because he says that the galvanized will help seal any porosity in the cast fittings, but I though that natural gas and galv. don’t mix?
The only place I planned on using galv. would be a 12″ length of 1 inch at the building entrance from the meter.  After that I was going all black iron (in a crawl space and within the walls), but I was wondering about the fittings.
Thanks!
Jim
  1. JohnSprung | May 17, 2005 09:44pm | #1
    Ask your gas utility company.  The chemical content of gas varies from place to place.  Here in LA, I see black pipe and galv mixed all the time.  Taking apart 80 year old stuff, the insides look fine on both.
    -- J.S.
  2. mike4244 | May 17, 2005 10:37pm | #2
    Galvanized is used extensively for gas lines outside.There is no problem that I know of using black iron and galvanized together.
    mike
    BillHartmann | May 17, 2005 10:53pm | #3
    The 'problem' with galvanized pipe is that some of the galvanizing might flake off.
    I would only use it before the drip leg.
    1. JohnSprung | May 18, 2005 03:03am | #4
      Drip legs are another thing that varies from place to place.  I don't remember seeing many out here.
      -- J.S.
  4. DanH | May 18, 2005 04:09am | #5
    It used to be (like 60-80 years ago) that galv pipe had a less than exceptional seal of the linear seam, meaning that it could leak gas if a piece was a sigma or two off the mean. (Or a least this is what I was told by an old gas man.) But I believe that manufacturing practices have changed since then such that there is essentially no difference between black and galv now, other than the galv coating.
