i’m building a house and thinking about finishing the exterior with galvanized aluminum sheeting, similar to what frank ghery has done. questions: cost vs. stucco, durability and strength. what goes underneath the sheeting? any advice, thoughts are welcomed
Aluminum oxidizes to produce its own protective finish. Galvinizing is for steel, not aluminium. Is your house already designed? Are you just trying to substitute a cheaper material? Or, are you trying to make a statement?
*MikeActually James is probably referring to Galvalume, a hybrid ribbed sheet metal much like old barn roofing. I use it a lot for roofing. It comes preformed in 32" wide sheets, in any length you can realistically ship. I've installed it on roofs and side walls in 20'+ lengths. To answer the original question, it should be applied on walls and roofs over horizontal strapping, 24"oc is good. It can be attached with special nails or screws (which I prefer) which come clour matched for the myriad colours it is now available in. I don't think it is at all cost effective for walls, but is extremely cost effective on new roofs where significant savings are realised in not paying time & material for solid sheathing, not to mention it's lifespan of . . . forever?As far as the look is concerned it's definitly not to everyones taste as a sidewall material. The house that I applied the 20'+ wall sheets to was designed by a young interning(?) architect for his parents. The centre of the house featured a soaring tower/light well that was further accented by being a red galvalume box, sides & roof, in the middle of cedar board & batten. The locals took to refering to as the 'silo', one of my lumber suppliers told his driver to look for Taco Bell north!
thanks for the information about galvalume. does it come in other patterns besides the standard wavy one? yes, i'm aware it makes quite a 'statement' but that's what i want- a metal, industrial finish. why is it more expensive as a wall covering than stucco/shingle/brick? longterm, i should make it up in zero maintenance, no painting, perhaps?
i'm building a house and thinking about finishing the exterior with galvanized aluminum sheeting, similar to what frank ghery has done. questions: cost vs. stucco, durability and strength. what goes underneath the sheeting? any advice, thoughts are welcomed
James
You would have to do some hard number crunching to compare sidewall galvalume costs with stucco, brick etc. Just get square foot $$ for each as a guide. I was comparing it to wood siding such as claps, or b&b, or god forbid vinyl or aluminum. Zero maintenace is one of the big benefits!!
Afraid your stuck with "wavy" pattern, it is after all a roofing material. There are several 'styles' to the rib pattern including a very "boxy" one used specifically for sidewall. . .looks way too clunky for my taste but might suit your industrial aesthetic. If you really want to make a statement include a couple of colours. The project I described with the red metal tower & roof had two intersecting roofs clad with slate blue galvalume!! Loooks. . . interesting!
