Galvanized roofing metal
Sailfish | Posted in General Discussion on September 30, 2009 05:03am
What do you think about putting this in direct contact with PT 1×4?
What about the metal roofing screws too?
Any of it react with the PT?
“I suspect the only reason 110 rounds was all that was fired was that’s all the ammunition they had” -Sheriff G. Judd.”
  1. fingersandtoes | Sep 30, 2009 07:30am | #1
    I would provide a gasket of some material between them, then you are only worrying about the fasteners.
    You do mean galvanized not galvalum roofing? Can't have galvalum anywhere near ACQ.
  2. Scott | Sep 30, 2009 07:35am | #2
    Why do you need PT lumber up there?
    But if you do, I'd be putting 15 lb felt over the straps, then the steel. Like fingers said, you still need to think about fasteners that won't be eaten by the ACQ.
    Scott.
      Sailfish | Sep 30, 2009 04:17pm | #3
      Its a pergola that we're going to put the galvanized (26g galvanized not galvalume)
      So felt would be out (ohh unless I want to make strips of felt, that I guess is an option). Time consuming but an option-----------------------------------------------------------------------------
      "I suspect the only reason 110 rounds was all that was fired was that's all the ammunition they had"
      -Sheriff G. Judd."
        Dinosaur | Sep 30, 2009 06:51pm | #4
        Grace membrane on the 1x and SS screws.
        But you don't need the PT. No ground contact, no trapped water.
        Dinosaur
Drafting the 2027 IRC
  • The New Old Colonial
