Gambrel Truss
pennycent | Posted in Construction Techniques on September 12, 2015 01:11am
Hello, I am puting together and 12×16 shed. I would love to use the gambrel roof for a little extra room. The walls are planed to be about 7′  IMy issuse is I need to keep the peak of my roof as close to 10′ as possible. Sorry if it’s a silly question, but can anyone help me with the demensions for the trusses? I realize it will likely go above 10′ just trying to keep it as close as I can. Thank you for and help.
    deadnuts | Sep 12, 2015 07:33pm | #1
    Why do you necessarily need trusses for this small of a shed?
    The upper (lower) pitch of the gambrel will depend largely on the roofing material you use and the proportions you desire. If you're going to use asphalt shingles, then most manufacturerd recommend a pitch of 3/12 or greather. Why don't you lay out your roof to scale (you know the orientation of the gambrel; not us) on a piece of paper to see what you get? You can likley frame this up conventionally and stay within dimensional lumber span allowances.
  2. SquishyMit | Sep 13, 2015 07:41am | #2
    Gambrel Truss Calculator
    I built a 24' x 40' gambrel barn last summer.  This site was VERY helpful in designing the site-built roof truss we used.  Check it out!
    http://www.blocklayer.com/Roof/GambrelEng.aspx
FHB Podcast Segment: Roofing on Commercial vs. Residential Buildings
In certain scenarios, flat roofs make more sense than pitched roofs (and vice versa).
  • A Postwar Comeback
