Can anyone explain why my circular saw can gang-cut 3 sheets of fiber cement, but not 6?
![](https://images.finehomebuilding.com/app/uploads/2024/07/16103615/01232548-cost-of-building-house-feature-thumb-16x9.jpg)
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
Simple answer, what size blade and/or what kind of saw?
Other question, why the question?
Talking standard 7-1/4" circular saw. Reason is just curiosity.
What size abrasive blade in it?
You can’t cut a 4x4 with a 7-1/4” in one pass.
So, to cut 3” of cement board……..?
I'm talking lap siding or soffit thickness, not 5/4 trim.
Sorry for my not knowing what you were cutting.
Add up the thickness of whatever you are cutting and what do you get?
Turn your saw over and measure from the base to the tip of the blade.
What do you get?
Thanks.
Fiber cement is typically 5/16" thick, so 3 sheets is almost an inch and 6 sheets is almost 2". Any circular saw should be able to cut that deep. But my saw goes a foot or so and then starts to wander and bind instead.
Blade problem or lack of saw power.
Too much friction.
Do you clamp the material together? The slightest movement of material could cause it to bind.
Yes, always clamped. Tried 2 different blades with the same result.
I’d guess then that it narrows it down to the saw itself.
This from an old carpenter that has never ganged up fibercement.
Maybe someone will come with the answer.
Best of luck.
If the blade gets very hot it can warp and start to wander
