Garage Door: 4 or 5 Panel?
kgregor4 | Posted in General Discussion on October 25, 2006 01:41am
In an earlier thread I inquired about retrofitting insulation to a door. I’ve decided not to go that route, but elected to go with a new door.
It’s a double door, 16′ x 8′. Any functional (ie, not appearance related) pros or cons to a 4 panel vs 5 panel design?
    IMERC | Oct 25, 2006 01:54pm | #1
    4 panel is stronger..
    WOW!!! What a Ride!
  2. scrumseeker | Oct 25, 2006 01:56pm | #2
    A 5 section door will transition through the track radius more smoothly than a 4 section door will because of the shorter distance between pivot points.  However, I think you would only notice the difference if you had the two options installed side by side.
    1. DanH | Oct 25, 2006 01:59pm | #3
      The 5-panel would in theory allow a tighter radius track, which might be important in low-overhead situations. Not sure how easy it is to find a tighter radius track, though.Otherwise I don't see the point in a 5-panel door for a standard height door.
      Seven blunders of the world that lead to violence: wealth without work, pleasure without conscience, knowledge without character, commerce without morality, science without humanity, worship without sacrifice, politics without principle. --Mahatma Gandhi
  3. mikeys | Oct 25, 2006 04:10pm | #4
    I don't remember how many panels but I once installed my own 8' tall door and it often refused to go all the way up.
    I finally had a garage door company out to adjust it and the tech worked a couple of hours, said my install and adjustment was good ,and the problem was that I should have had 1 more panel.
Townhouse Transformation
A sleek, modern redesign maximizes space and light while preserving the building's historical charm.
