garage door header requirements
matasky | Posted in General Discussion on June 29, 2007 01:57am
i don’t have a code book available right now, hence my question…
can anybody give me the wood framing requirements for a garage door header…opening is 8ft wide, 2×6 framing, and snow load is not a factor here in bermuda :)…
back in canada i know steel beams are the norm, but i’m wondering if they are necessary for this situation…
thanks
  1. fingersandtoes | Jun 29, 2007 02:16am | #1
    What load is the header picking up? If nothing, then all you need is backing for the spring.
  2. stevent1 | Jun 29, 2007 02:17am | #2
    Matasky,
    Are 2 X 6 the walls? What type of wind shear?  Storage above? Free standing or attached?  More in info is needed.
    Chuck S
  3. Stilletto | Jun 29, 2007 02:32am | #3
    I like to use 2x12's as a minimum,  overhead door vertical tracks usually extend 12" above the RO,  a 2x12 header gives them lumber to mount everything to.
    Matt
  4. Dave45 | Jun 29, 2007 02:37am | #4
    My 16' garage door (in CA) has a 4x12 header.  Roof is gable end, no snow load.
  5. smithland | Jun 29, 2007 02:48am | #5
    Could go to a lumber store or web page and find a engineered lumber catalog  which  will have tables for load and spans.It will give you sizes of ther product (lVL , Timberstrand ect.)  then either use the same size or a little larger for you local available or Dimension lumber for your header.
  6. dovetail97128 | Jun 29, 2007 02:54am | #6
    matasky,
    The header is carrying what load?
    Truss roof, stick built?
    Ridge beam?
    Can't answer with out knowing loads.
    "Poor is not the person who has too little, but the person who craves more."...Seneca
  7. arnemckinley | Jun 29, 2007 04:27am | #7
    8ft span; truss roof, conventional framed, or hip roof, a double 2x12 header and double trimmers will be plenty. depending on local codes you might have to use hold downs, but i don't really know without knowing.
