Garage door opener hates the cold
nater | Posted in General Discussion on October 6, 2009 06:04am
I’ve got a 2 or 3 year old Genie garage door opener that hates the cold. It works fine all summer, but with the cooler weather, as soon as it hits 40 or so, it acts up. Its a 1/2 hp chain drive that I bought a couple years ago.
What happens is it will open fine, but when you go to close it when its around 40 or below, it goes down partway, then acts like it hits an obstruction, and opens back up. The door seems to still move freely, so I don’t think its the door itself, but I may be wrong. If I fight with the controls, I can eventually go down, stop the reverse, go down, stop the reverse, go down until it closes all the way.
I don’t want to increase the down pressure and risk breaking something, but I could if I have to. Any ideas to try?
    IMERC | Oct 06, 2009 06:16pm | #1
    suspect humidity/condensation.... it's screwing with the circut board...
    does the dryer vent into the garage...
    WOW!!! What a Ride!
  2. calvin | Oct 06, 2009 06:38pm | #2
    I might think that you could increase the closing (auto stop) power just a bit to see if cold lubricant on the chain drive is telling it that your cat is being crushed.
    Some folks grease the interior channel of the track (not necessary) and that thickened glob might be just enough to override the closing force.
    Other than that, beats me-dumb carpenter/not garage door officianado.  Until this 13 yr. garage, had to get out and push.
    http://www.quittintime.com/
  3. DanH | Oct 06, 2009 07:11pm | #3
    My guess is that it's not well balanced, and the up force from the springs is causing the reversal. The force of the springs will vary a fair amount with temperature.
    Release the door from the opener chain/belt and see how easily it goes up and down by hand, and where it tends to balance.
    Also, check that the photocells are properly aligned.
    As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
  4. JTC1 | Oct 06, 2009 08:22pm | #4
    Well I was going to say:
    Balance / spring tension, or roller lube, or down-force adjustment.
    You said:
    >>The door seems to still move freely, so I don't think its the door itself, but I may be wrong.<<
    This seems to clear out the balance / spring tension and roller lube possibilities.
    Leaving the down-force adjustment as the probable culprit.
    Where is your down-force adjustment set now?
    My opener has a sort of scale around the adjustment screw and is very near the "lightest" setting.  If your's is set at minimum or very close to the minimum, I would not hesitate to increase the down-force adjustment. Make small adjustments and try it.
    Might lube the rollers with some machine oil and check operation before adjusting anything - pay close attention to "bumps" or "snags" during the door travel - they could be your problem.
    If you increase the down-force -- perform the "paper towel" test after adjustment.  Stick a full roll of paper towels, laying on it's side, perpendicular to door face into the door closing area - close the door onto the roll - door should reverse - if it does, it's OK. Inner tube of the roll will crush - that is OK.
    Jim
    1. handycraftsman | Oct 06, 2009 10:08pm | #5
      you also may need to apply a little lubricant to the openers main beam.  I've ran into this on a service run once.  The beam was very dry where the traveler runs and friction was reversing the opener.  Lubed beam and problem solved.
      IMERC | Oct 06, 2009 10:11pm | #6
      says the OP...
      I've got a 2 or 3 year old Genie garage door opener that hates the cold. It works fine all summer, but with the cooler weather, as soon as it hits 40 or so, it acts up.
      WOW!!! What a Ride!
      1. JTC1 | Oct 07, 2009 03:50am | #12
        So you are thinking track contraction or what?
        If condensation was a problem with the circuit board, I wouldn't think he would get it to work at all once it was in the "act-up" mode, but he says he can get it to work eventually.  Unplug, open 'er up and spray the board with an electronics dryer? Wouldn't hurt, might work!
        I did a search of the archives on this, but I got the pipes thread......;^)
        JimNever underestimate the value of a sharp pencil or good light.
          IMERC | Oct 07, 2009 06:11am | #16
          condensation inside of the the drive unit... dryer was vented into the garage... moisture was forming up on the walls and eveywhere else and took a guess that condensation was affecting the unit..
          stuck a hair dryer into the unit and warmed it up for some time... it started to work pretty well... removed the hair dryer and a few hours later it stared up with the odd behavior again...
          2nd time I came across this the washer and dryer was in the garage.. same thing...
          the 1st one rerouted the dryer vent to the out doors...
          2nd one installed a dryer vent to the outdoors...
          incase of medicince was to get some non conductive circut board sealer from a real electronics store and make the board water resistant...
          so far it's 4 for 4...
          WOW!!! What a Ride!
          1. JTC1 | Oct 07, 2009 02:16pm | #17
            Never seen that one, but sounds reasonable.
            Probably because of local climate - humid all year!
            nater | Oct 07, 2009 03:36pm | #18
            It does it anytime of the day, or night, so I'm pretty sure that it isn't a sensor issue. I can watch the lights on the sensors and see that they never blink like when there is an obstruction.Nothing moisture producing in the garage, dryer vents out the other side of the house.What kind of spray lube do I need to use? I know that the last opener I put in (screw type) said to use a special lube on that, but it was a grease I think.
          3. Grier | Oct 08, 2009 10:30pm | #34
            Mine quit working because of a barely visible spider web that the sensors kept catching.
            Spiders came in when it got cold.
            Work for the greatest vital intensity - the greatest solidity and aesthetic reality. Finally, eliminate everything non-essential. Reduce to the absolute essence. ~ F.C. Trucksess
            IMERC | Oct 07, 2009 03:41pm | #19
            warm up the interior of yur unit with a hair dryer really well...
            costs nothing but a little bit of time and if that's the problem....
            WOW!!! What a Ride!
            nater | Oct 07, 2009 04:51pm | #20
            Yep, but if thats the solution, my DW isn't gonna want to climb on top of the car to do that every time to close the door.
            IMERC | Oct 07, 2009 04:59pm | #21
            duct tape it in place and remote switch it..
            WOW!!! What a Ride!
          7. DanH | Oct 07, 2009 06:39pm | #22
            But the DY still won't like that when she has to climb up there to dry her hair.
          8. User avater
            IMERC | Oct 07, 2009 09:45pm | #24
            duct work...
            WOW!!! What a Ride!
          9. jimAKAblue | Oct 07, 2009 09:40pm | #23
            A bonfire would be more fun.
          10. User avater
            IMERC | Oct 07, 2009 09:45pm | #25
            napalm..
            WOW!!! What a Ride!
          11. jimAKAblue | Oct 08, 2009 04:00am | #28
            Nuke
          12. DanH | Oct 08, 2009 04:08am | #29
            What does he know about GDOs??
          13. jimAKAblue | Oct 08, 2009 07:34pm | #30
            Hopefully, more than me.
  5. Piffin | Oct 07, 2009 12:07am | #7
    How often do you use a spray lube on the rollers and such?
    I was surprised when reading ( yes, I'm one of those strange guys who actually read the instructions) that you are supposed to tend to this duty monthly!
    I suppose for most people the answer is never, while a few of us do it once a year or so.
    That - dry wheels turning hard - or a mis-aligned track can add load to the resistence sensors. I would try checking lube and alignment before adjusting the down pressure.
  6. Dave45 | Oct 07, 2009 02:36am | #8
    Where is the sun when this happens? My garage door acts up in the winter when the sun is low and the receiving unit of the safety sensor gets direct sunlight. Last year, I moved the receiving sensor back and the problem disappeared.
    1. DanH | Oct 07, 2009 02:39am | #9
      Yep, I was going to suggest the same possibility. When the thing acts up, stand in the way of the sun hitting the photocell and see how it works. If it's found to be a problem a sun shield can probably be devised using a piece of scrap plastic.
  7. gotcha | Oct 07, 2009 02:41am | #10
    I probably adjust my opener 2-3 times a year.
    Why....? just have to to get it to work.
    Pete
    1. DanH | Oct 07, 2009 02:45am | #11
      Haven't touched mine in probably 10 years -- even to lubricate. The springs were replaced (converted to torsion), but didn't touch the opener.
      1. gotcha | Oct 07, 2009 04:35am | #14
        My door is the 16', 26 yr old unit when the house was built.
        It's heavy enough to obviously cause occasional adjustment problems.
        My old opener didn't have a problem. Maybe the new one is too sensitive.Pete
        1. DanH | Oct 07, 2009 04:51am | #15
          Our door is 33 years old. Heavy 16' Masonite unit. The opener is about the same age.
  8. scrumseeker | Oct 07, 2009 04:20am | #13
    Garage doors and openers do tend to work harder as the temperature drops.  Gnerally this can be corrected with a slight increase in the down force adjustment.
    If you are concerned about too much pressure you can test the reversing pressure by hand after it is adjusted
    I think if the problem was related to the photo cell sensors than you would have an indication of that by the light on the unit flashing (like it does when you cross the beam during normal down operation.
  9. McMark | Oct 07, 2009 10:10pm | #26
    What type of door is it?  If it is wood, humidity can affect the door itself, warping and growing.
  10. Norman | Oct 07, 2009 11:36pm | #27
    Another possibility, bad solder joint. Warm weather, wire expands and makes contact. Cold weather, wire contracts, contact is gone.
  11. User avater
    PeteDraganic | Oct 08, 2009 07:54pm | #31
    I have trouble when it snows. Snowflakes will actually break the beam and cause the door to go back up.
    I refuse to accept that there are limitations to what we can accomplish.        Pete Draganic
    You can lead a moderator to a computer, but you can't make him think.          cussin2
    1. DanH | Oct 08, 2009 08:00pm | #32
      The solution to that is to move the sensors up to the ceiling, above the door, so that no snow can reach them.
        PeteDraganic | Oct 08, 2009 09:30pm | #33
        its a good thing the kids are taller now.
  12. barmil | Oct 09, 2009 04:10am | #35
    Given all the varying and confusing advice, I'd just call Overhead Door and be done with it. It's not getting any warmer now.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
