Garage door opener noise isolation
| Posted in Construction Techniques on February 24, 2005 07:08am
Need some advice on how to isolate these garage door openers so the noise is lessened.  They are attached to the 12″ floor joist, and the room above is a bedroom with wood flooring over advantech.  There is fiberglass batt insulation in the cavity, but with a direct connection to the framing … it makes for a great alarm clock in the morning.  Don’t think it matters, but the doors are metal, one a single and one a double.  Ceiling height in the garage is about 12 ft.
I’m sorry, I thought you wanted it done the right way.
  1. edwardh1 | Feb 24, 2005 07:17pm | #1
    probably something the manufacturers have not thought about. they could prob fix it with rubber mounting of the motor and pull up track.
    i have same problem over a den
    wonder if architechs think about this?
    park outside?
      CapnMac | Feb 24, 2005 11:17pm | #6
      Some do, some don't, kind of like contractors, in that it's one of those "if the customer permits" situations.  If you're being hounded by the customer to be faster, or to be cheaper, or to be better (or any combination of those), it's easy to lose focus and "miss" a thing or two.
      Unless you've lived in close proximity to a low-bidder or all-budget-will-allow opener, it's easy to forget just how much noise there is.  Remembering that there's a bedroom over that opener while working on the floor plan with the garage can be a problem too.
      My reflex guess is that there were no specs for the opener, other than to install per mfgr's instructions.
      The straps almost rubbing the fluorescent tubes caught my eye, too. Occupational hazard of my occupation not being around (sorry Bubba)
      1. FastEddie1 | Feb 25, 2005 01:55am | #8
        The house is only 4-5 years old, and shows signs of much corner cutting.
        The v-belt idea sounds neat, using large s-hooks on each end.  I like the mud flap too, if I can find one that is fabric reinforced.
        One of the straps is actually touching the tube.
  2. boulderbuilder | Feb 24, 2005 07:26pm | #2
    go to a glass shop and get a dozen or so chunks of rubber (they use them for shimming insulated units).  at the bolted connections to the joists and at the drive unit itself, interupt all the metal-metal and metal-sheetrock connections with a chunk of rubber.  you made need to lenghten some of the fasteners depending upon how thick of rubber chunks you get, shouldn't need to be anything over 1/2".  oil and lube motor and track.  good to go!
    Dave
    IMERC | Feb 24, 2005 07:57pm | #3
    WTB the light fixture is acting as an amplifier..
    you can put machine vibration dampers between the brackets, units and cieling...
    spread the mounting bracket's foot print out over a larger area...
    WOW!!!   What a Ride!
    DDay | Feb 24, 2005 08:26pm | #4
    I haven't done it but I've heard of using belts (like old car serpetine car belts) instead of the metal angle to mount the unit to the ceiling.  They leave the angle bracket that is on the ceiling and replace the two drop down pieces with belts.  Those units don't weight very much and belt will hold up an elephant.  They also put a piece of rubber between the wall mount and the wall to stop the vibration.
    Also check the tension on the chain of the operator.  The chain should be snug and pretty flat, if you see the chain dipping down then the noise would be a chattering type of noise which is the chain rubbing against the track guide that the arm going to the door clicks into.  We also have liftmaster's and sometimes the chain loosens and rubs on that guide.  If it wasn't doing it from day one then this is probably the problem.
    BillHartmann | Feb 24, 2005 08:45pm | #5
    That looks like an old chain drive. Exactly like the 25 YO unit I replaced last year. If that one is of a similar age time to repace it anyway.
    You can start by replacing it with a Wispher Quiet belt drive unit (or similar from another Stanely or Marantec).
    On Ask This Old House, Tommy used a mud flap to isolate the opener.
    3-5 bolts with washer through it to the angle iron in the ceiling.
    Then down a couple of inches install a 2nd angle iron that attaches to the opener.
    But if you use any kind of rubber isolation I would also install a safety chain.
  6. USAnigel | Feb 25, 2005 01:52am | #7
    I just replaced the old sears unit and with it there was a loud rumble when the door opened. Replaced with a chain in the track type (got it cheap). Still rumbled! Went to PEPBOYS picked up exhaust rubber strap hangers and installed to break the solid metal hangers. This alone has cut the noise by half! Worth a try!
  7. WayneL5 | Feb 25, 2005 02:19am | #9
    You can buy sound isolation hangers from an industrial supply company such as http://www.mcmaster.com.  It's important to get the right weight rating and type.  If you get one too stiff it won't do any good.
  8. junkhound | Feb 25, 2005 02:53am | #10
    Well, if I tried to totally quiet down the opener on the bay for my truck DW would be all on my case about trying to sneak in too late at night!
    <G>  -I've left the squeak in it even.
