Garage door to sliding barn door ???
TomW | Posted in General Discussion on August 26, 2009 06:17am
I am considering replacing the door to my basement garage door (boat door as some refer to it) with a sliding barn type door. I am interested in constructions details, best practices for creating a good seal, hardware recommendations, etc…
Exterior wall is brick veneer.
Anyone done this and wish they hadn’t. Specific pitfalls I need to be aware of?
  1. GregGibson | Aug 26, 2009 06:51pm | #1
    Never done one - just an observation here.  I would consider this to be somewhat obscure hardware, but my local Lowe's store stocks the track and rollers, all the sliding door hardware.  I can't believe they sell many units here in South Georgia, but there it is.
    Check your local store.  I like to see something for myself, first hand.
    Greg
    1. TomW | Aug 26, 2009 07:03pm | #2
      They sell the hardware at the stores close to Atlanta as well. Not sure it's the best hardware for the application though. I would also love to see some good install pictures.This is the perfect solution for my application but only if it can be made to work well and seal well, or at least as well as a typical garage door.
  2. fingersandtoes | Aug 26, 2009 07:12pm | #3
    Several years ago FHB published a house that had one wall of the living room that swing away on barn door hardware. In was sealed on all four sides with gaskets - something that would be a bit harder with a garage door on a slab.
    I've used garage door hardware on shops but never with the intention on making them particularly weather tight. Ideally the track would have a kink in it that brought the door in tight as it reached its closed position - much like the mechanism on a mini-vans side door, or perhaps rollers to keep the door angled out once open so that the gasket didn't rub along the wall and door jambs.
    1. TomW | Aug 26, 2009 07:34pm | #4
      It seems like that could be accomplished fairly easily by angling the track, i.e. spacing the open end of the track farther away from the wall. Sealing the bottom of the door is probably the hardest part although angling the track upward slightly may be enough to accomplish that if I can find a seal that will work.I can envision some cam type mechanisms that would work but it adds a level of complexity that I don't really want to get into. Simple and reliable is the goal.
      1. john7g | Aug 26, 2009 07:47pm | #5
        have you seen this?
        http://www.barndoorhardware.com/
        1. TomW | Aug 26, 2009 09:22pm | #6
          I did. There is some nice stuff there. I haven't found any good details of jambs and such though. Shouldn't be that hard to design something but there isn't much sense in reinventing the wheel either.
          1. fingersandtoes | Aug 27, 2009 02:29am | #8
            I was in Costco today and noticed that they use sliding doors for access to their bulk freezers. They had built up a 2" deep surround clad in smooth steel onto which the fully gasketted door fit very tightly - and it was on a slab. The hardware was heavy duty but quite similar to all the other barn door tracks I have seen. A handle similar to that found on all commercial freezers pulled everything tight. Sorry I couldn't see any label to identify the manufacturer. Do you have a Costco card?
          2. TomW | Aug 27, 2009 03:48am | #9
            No, no cosco here that I am aware of. I may check one out when I visit my folks in Mass.
          3. john7g | Aug 27, 2009 03:54am | #10
            try this
            seems there's a new one (or at least one I hadn't known about) not too far off your daily route.
            membership has def paid off buying diapers and formula there.
          4. TomW | Aug 27, 2009 04:00am | #11
            I drive that way every day and I think that is just a warehouse, not a retail location.
          5. john7g | Aug 27, 2009 04:07am | #12
            I shoulda went with their site: http://www.costco.com/Warehouse/locator.aspx
  3. oops | Aug 27, 2009 12:46am | #7
    I have done 2 or 3 over the years. A good seal will be a real challenge/problem. They are not made/designed to seal. That is the reason they are not used much these days. The operation is very loosey goosey.
Mortar for Old Masonry
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
