I have a attached garage and the shared wall that is covered with a brown fiberboard and would like to remove the fiberboard, upgade some wireing and reinsulate and finish it with drywall that would meet the firewall codes for minnesota, so what type and thickness of drywall do I need and how should I finish it?
![](https://images.finehomebuilding.com/app/uploads/2024/05/23122928/01232448-bracing-for-storm-thumb-16x9.jpg)
Insurance industry research shows that stout roofs, strong windows, and metal connectors can help protect houses from high wind, hail, and hurricanes.
http://www.gypsum.org/GA60006.html
Download the Gypsum Association Fire Resistance design manual. You'll know more than anyone else
Welcome to Breaktime, if you beak your posts up into scentences and paragraphs it will be much easier to read, and you'll probably get more responses to your posts, since they'll be easier for everyone to read instead of them havnig to try to figure out where you should have put punctuation in.
LMAO! You're in rare form today.
Picken on the new guys again!? ;}
ted
MI required 5/8" x in the localities I worked. Texans don't have garages.
Munincipalities may have their own codes. Typically, 5/8" FC (firecode) is required all the way to the rafters. It has to be taped one coat but not finished and sanded, unless you want to. There can be restrictions on the entrance doors from the garage to the house, too. The best way is to know is to call your local building codes enforcement office.
Fire rated walls rely on the whole wall assembly, not just the drywall. Here in Canada the common ones are shown in our building code.
