Garage to House door = exterior door?
Is a door that goes from the attached garage to home considered a exterior door or interior door?
I assume since the garage is not as insulated as the home due to the large doors that you would want a door that is well sealed, i.e exterior door. Does this make sense?
Unless you live somewhere without weather, you'd definitely want an insulated door.
Most codes require the door to be fire rated anyway, and all fire rated doors have insulation to slow the movement of fire from garage to house. You could not meet code with a hollow interior door.
That's what I figured Wayne, thanks. Again I assume the r.o. is the same as a "normal" exterior door.
Yes. Of course it is always safer to buy the door first.
neither - it is a fire door - as such, it needs to fit snug to prevent drafting
For what ever its worth, the door on my house connecting the garage to the utility room is what appears as an interior raised panel pine door. The side facing the inside of the garage has a sheet of metal covering it, pained white. The jam is sealed with a spring bronze strip around the perimeter.
Probably not insulated the best but looks better than the average steel stamped raised panel door.
When I wanted to replace my garage entrance door, the door shop was able to provide me with a fire rated 6 panel hemlock door. The whole thing looks just like any other 6 panel interior door inside and out, save for the thickness and weatherstripping. That little plate saying it is a 45 minute fire rated door sits right there on the hinge side.
Wasn't cheep.
Now i'm really confused Pete. From what my local lumber supplier said they just sell some plain metal solid core doors to most of the local builders and they pass code with those doors.
I got mine from BMC West out here in Denver.
And I lied, it's a 20 minute rating, not 45.
Thanks for checking Pete.
Warnock Hersey is the manufacturer of it.
BMC puts the slab into a frame and retails it. BMC is a rather large building supply house out here.
Thanks Pete. I have a BMC about 20 minutes from me so i'll check.
BMC: Bowel Movement Coming as they are sometimes called here. ;-)
Just to clarify:
Warnock Hersey is a testing agency , not a manufacturer. The tag is put there to prove the door assembly ( which includes frame, gaskets etc. manufactured the same way as your door) has met the testing agencies tests for a 20 minute fire rated door. Used to be that all garage/house doors had to be 20 minute and have have self closing hinges or closers. Not that way here any more, requirement for the closures was dropped.
Thanks for the clarification.
The self closures are nice even without the requirement.
Our code dictates that the garage be separated from the house by a 45 minute rated assembly, and that includes the door. It also has to be smoke tight and self-closing.
blownonfuel,
The fire rated doors we use are of the metal split jamb type and the RO is usually different then normal. Also, you would want to specify the wall thickness so you get the right size range. Get the door and read instructions.
Vince
Vince Carbone
Thanks Guys. For some reason my wife wants a door with lots of glass going into the garage, I guess thats out of the question now.
You might find a door with a fire shutter in the glass, but it would have an industrial look.
It is an ironic habit of human beings to run faster when we have lost our way. --Rollo May
Wired glass has a 45 minute fire rating, if she doesn't mind the look. I don't think any clear glass does.
Here's what the 2003 IRC says:
"309.1 Opening protection.
Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 1 3/8 inches (35 mm) in thickness, solid or honeycomb core steel doors not less than 1 3/8 inches (35 mm) thick, or 20-minute fire-rated doors."
What code are you under?
Jon Blakemore
Thanks Jon. 2003 IRC. I went to the big box store and was told that all of there doors except for one are all fire rated. Does this sound correct?
My knowledge of fire ratings is not as exhaustive as it could be. The big box guys may be correct that the "doors" are fire rated, but a savvy inspector would also make sure that the frame is fire rated as well.Also, what does it mean to be "fire rated"? Once you do a little commercial work, you will quickly find that everything that is fire rated will likely have a UL spec attached to it that will tell you exactly what that means. There's a big difference between a 20 minute door and a 4 hour door, and I'm sure there are many other criteria that come in to play for your various building use groups, where the door is in the building, etc.
