Gas fireplace enclosure finish detail???
MisterT | Posted in General Discussion on June 2, 2009 02:36am
We have installed a empire gas FP fir a cust. .
following the directions we stopped the drywall at the stand-off height, thinking that the available trim kit would cover the 3″ area.
WRONG….
so how are you supposed to enclose this area in a simple no surround application?
Use durock and mud it smooth??
The directions are not real clear on this.
we will prolly end up tiling with some durock but it would be nice to have a factory finish trim that would cover the ENTIRE rough opening…
BTW the HO got the FP from a P&H supply and dealt directly with the owner (yeah I know)
If you want good service go to a professional dealer but if you want things really screwed up deal with the owner…
any words of wisdom out there???
“After the laws of Physics, everything else is opinion”
-Neil deGrasse Tyson
If Pasta and Antipasta meet is it the end of the Universe???
according to statistical analysis, “for some time now, bears apparently have been going to the bathroom in the woods.”
  1. rez | Jun 08, 2009 06:32pm | #1
    Greetings MrT,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    94969.19  In the beginning there was Breaktime...
    94969.1  Photo Gallery Table of Contents
    1. MisterT | Jun 08, 2009 06:37pm | #2
      Thank You rez..
      "After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
      according to statistical analysis, "for some time now, bears apparently have been going to the bathroom in the woods."
  2. PedroTheMule | Jun 08, 2009 06:48pm | #3
    Hi MisterT,
    we will prolly end up tiling with some durock but it would be nice to have a factory finish trim that would cover the ENTIRE rough opening...
    I had a similar problem with a "freebie".....almost as bad as a "owner provided". My freebie's trim was long gone.
    I simply used the same material (tile in this case) that I finished the hearth with to fill in. I had a bit of extra spacing and ended up with three narrow layers of durock prior to the tile finish surface.
    Lived there for years and never had a problem.
    Pedro the Mule - my fur stands in fear of fireplace sparks
    1. MisterT | Jun 09, 2009 02:57pm | #4
      yeah that is what is gonna happen.but it would be nice for the install instructions to point out:this little 3" strip that needs to be non-combustible, and appears to float needs to be extended back to solid support, because or trim package won't cover..
      1. PedroTheMule | Jun 09, 2009 06:18pm | #5
        Hi MisterT,
        Was it made in China?
        Pedro the Mule - Always missing something from my China packages
