Gas fireplace pipe
finefinish | Posted in Energy, Heating & Insulation on March 18, 2013 06:01am
Hello everyone,
    I’m installing a Jotul propane fireplace and am using a Simpson wall thimble and Simpson 5/8 Duravent pipe.  Does anyone know what type of sealant can be used to seal the 1/8″ gap around the vent pipe where it passes through the thimble?  This is the one detail that the instructions don’t explain.  From inside I can see a sliver of daylight.  Is a regular high heat silicone okay to use here?  I’d appreciate any advice you may have.
  1. rdesigns | Mar 19, 2013 10:35am | #1
    The manufacturer's instructions for the Duravent pipe will want either 1" or 2" clearance to combustibles, and since hi-temp silicone is not a combustible material as defined in the codes, the answer is, yes, you can use if for a sealant.
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
