Gas Fireplace Problem
Ledebuhr1 | Posted in Energy, Heating & Insulation on October 12, 2018 11:09am
My Heat-n-Glo fireplace wont ignite. I just replaced the thermopile, and it dident solve the problem. The Pilot light works fine. When I flip the button to turn it on noting happens. Any idea what would cause the main burner from igniting?
  1. florida | Oct 12, 2018 12:59pm | #1
    The pilot or burner could be clogged or the regulator isn't working. Are you sure you have gas and that it's on?
    1. Ledebuhr1 | Oct 12, 2018 04:53pm | #2
      Yes,the gas shut off valve is on.  I'm thinking that the problem is with the electric valve that opens when you turn it on. I guessing that its stuck closed, due to lack of use. Is there anyway I could take this valve off and test it or excersise it?
      1. user-3014192 | Oct 20, 2018 04:39pm | #3
        Gas stove
        My stove has a remote thermostat that I just replaced for the same problem.  Sounds as though yours has an on/off switch on the stove. Could you take the switch off and connect the 2 wires and see if it goes on.  If so, the switch is the problem, if not you've at least ruled that out.
  2. adymoore | Jan 19, 2023 01:07am | #4
    Have you tried inspecting the circuit breaker or the gas valves? I also read an article by Hurliman Heating about troubleshooting the gas fireplace that can help you solve your problem. After troubleshooting your gas fireplace, I recommend you ask for a professional from this company that I usually call when I have HVAC system issues.
