gas log problem
FastEddie | Posted in General Discussion on November 7, 2009 08:50am
We have gas logs in the fireplace and DW wants them to work for the holidays (notice i didn’t say Christmas … that would be politically incorrect).  the pilot comes on when I hold in the starter button, but goes out when I releas it.  Seems that would be either a bad thermocouple or bad gas block.
I pulled the TC and tried to check it with a meter.  Sitting cold, one lead against the tube and one against the tip of the connection, it reads about zero ohms.  When I place the TC end in a candle flame, the resistance goes up to 10-15 ohms.  Does that sound right?
“Put your creed in your deed.”   Emerson
“When asked if you can do something, tell’em “Why certainly I can”, then get busy and find a way to do it.”  T. Roosevelt
  1. DanH | Nov 07, 2009 10:43pm | #1
    Resistance shouldn't change much, but the TC should produce a few millivolts of voltage. If it's producing voltage, however, it could throw off the ohm reading, so hard to interpret that.
    When you try to start do you hold the button in for 30-60 seconds after lighting, to give the TC time to warm up?
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
    1. FastEddie | Nov 08, 2009 12:37am | #3
      Ok, I changed the scale on the vom and tried again.  Witht the end in a candle flame, I get about 25 millivolts.  Before I took it apart, I held the button in for about a min ute, and the pilot goes out as soon as I release the button."Put your creed in your deed."   Emerson
        coonass | Nov 08, 2009 01:17am | #4
        Fast Eddie,On one I worked on there was an oxygen sensor that was bad. KK
        1. FastEddie | Nov 08, 2009 06:08am | #6
          Mine is a regular vented set of logs in a true wood burning fireplace, thus no O2 sensor.
          I'll try the direct-force-adjustemnt method."Put your creed in your deed."   Emerson
  2. Shacko | Nov 07, 2009 11:13pm | #2
    Since thermocouples are cheap, I normally just replace them with a new one. Not being an electrician I think that your measurment is showing an increase in resistance, thats not going to get your valve to operate. All I know is they should be 20-30 millivolts.
    "If all else fails, read the directions"
    popawheelie | Nov 08, 2009 01:23am | #5
    I noticed that some gas appliances get stuck or clogged after sitting for a while.
    You can hold down the button, light the pilot and keep the button down for a minute.
    But before you let up on the button give the valve a good wack.
    Sometimes the valve gets stuck from not being used.
    "There are three kinds of men: The one that learns by reading, the few who learn by observation and the rest of them have to pee on the electric fence for themselves."
    Will Rogers
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
