Gas Oven Problem – where to look?
McDesign | Posted in General Discussion on August 28, 2008 04:54am
24″ GE pilotless small gas stove in the aux. kitchen.  Bought new about (16) years ago.  All (4) burners (piezo ignite) work fine.
Electric (glow bar) ignition for the oven.  From cold, thermostat in the temperature setting dial goes “tick” when rotated, like it’s supposed to; strip starts to glow; gas comes on, no problem.
This will work for a couple of times, the gas cycling on and off to maintain the setpoint temperature.  After 15-20 minutes (as the case gets hot?), the burner will no longer come on.  The thermostatic dial still makes the little “tick” sound as it rotates back and forth over the inside temperature number, but no glow strip  action.
After it cools for a few hours, the same thing all over again.
I’m guessing there’s an overtemp sensor or thermister somewhere that’s gotten old?  Any idea where to start looking?
Can’t find the manual.
Forrest – doing honeydoos on vacation
  1. oldusty | Aug 28, 2008 05:04pm | #1
       Mc D ,
                   I'm no expert but had a similar problem , not exactly the same but it could be the electric ignighter / glow bar . What I did was swap the one from the broiler just to see if that solved the problem , mine worked fine so I only replaced the oven one . It only takes a few minutes to swap it out .
             good   luck      dusty
      McDesign | Aug 28, 2008 05:16pm | #2
      Hmm - good thought.  This tiny oven only has one gas bar - but the glow strip does look easy to replace - maybe I can figure out how to check it.
    Sphere | Aug 28, 2008 05:42pm | #3
    There is a wiper in the knob, like a rheostat or potentiometer, clean out the cat fur and grease.
      McDesign | Sep 22, 2008 05:05pm | #4
      Sphere -
      Thanks for that approach. I was convinced that because I could hear the <click> when I turned the oven temperature dial that the switch was working.
      Anyway, I measured voltage across the microswitch within the dial temperature control mechanism. 120 V when off, but not ALWAYS dropping to zero when I rotated the knob, though I could hear the <click> of the microswitch toggle leaf snapping closed every time - was worse when the oven was hot. Jumped the wires; oven came on fine every time I connected them.
      Found the switch assembly with thermal sensor online; like $70. Figured I'd at least pull apart the microswitch iffin' I'ze gonna' replace it. Found that the <click> indeed "made" the contacts, but that there was years of carbon between them. I could push the contacts tighter, and make the electrical connection, but the little internal snap spring (like a hair barrette) wouldn't always push hard enough.
      Cut a strip of 400-grit paper, couple passes over each side, works good as new.
      Now the maid has a working range.
      If we just had a maid.
      In the little outfit.
        Sphere | Sep 23, 2008 12:04am | #6
        Cool!
        er...Warm!
        Lemme know if'n that maid shows up, I may need to borry her.Spheramid Enterprises Architectural Woodworks
        http://www.youtube.com/watch?v=Dj_oEx4-Mc4
        The world of people goes up and
        down and people go up and down with
        their world; warriors have no business
        following the ups and downs of their
        fellow men.
    2. peteshlagor | Sep 22, 2008 06:12pm | #5
      You figger someone has been baking cats in there?
        Sphere | Sep 23, 2008 12:07am | #7
        He mighta got ona tear with his "Poetry Reading" drinking buddy and thought they were fireing clay tiles ...or something.
        Ya never quite know with Forrest.Spheramid Enterprises Architectural Woodworks
        fellow men.
