Gas to wood burning fp
bc | Posted in General Discussion on December 15, 2008 01:07am
Converting fireplace back to wood burning (the previous owner added a gas line and the gas logs). Disconnected the logs and shut off the gas. The problem im facing is that the gas line runs through a pvc pipe.
Should i try to remove the pvc pipe before patching the hole w cement? Any other steps thoughts on converting back to wood burning?
  1. ponytl | Dec 15, 2008 03:04am | #1
    i assume the pvc was to sleeve the hole for the black gas pipe?   the yes... punch it out or cut it back a few inches (use an inside pvc cutter or a small drimel type tool) then patch... i'd use something like rocktite that expands as it cures/sets... but you want to get the pvc out of flames /heats way   thats a fire you don't want to start
    p
    1. wane | Dec 15, 2008 04:08pm | #2
      "use an inside pvc cutter"
      got a link, never seen one, could have used one .. thanks ,,
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
