I have posted the same query in “Cooks Talk” but I thought I’d better check here.
I am looking for a 30″ or 36″ gas wall oven that can be converted to propane and that uses a spark ignition or match to light. Most of the units I have seen use a heat plug, which won’t work for me – we have a remote location (read “solar power only”) and need a unit that can run without a constant supply of power.
Verona makes a 24″ unit, but it is too small for our needs. Everything else I have seen is a stove unit with burners on top. Not too good for a wall unit.
Hoping you have some ideas.
Patrick
