Well, that’s what it sounds like. It has started to put out a ringing sound of 2-4 quick 1/2 second rings followed by a 5-6 second long ring.
These little sessions may occur at 4-5 minute intervals on for a qtr to half hour and then it stops. It’s not a whistling, tea kettle type sound like a pressure valve would make(I think) but more like the clear ring that you get from tapping a glass with a knife. Sould I be panicing? It is making hot water just fine and it doesn’t seem to be hotter or colder than normal. I wish I knew a plumber I could trust to do a good job, I HATE gas.
Tigger
Get it figured out yet? What was it anyhow?
If not ...
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
Peace full.
Some kind of expansion/contraction noise - possibly in the water lines? I doubt if gas has anything to do with the problem.
Do you drain it once a year? Do you have hard water? May be scale expanding/contracting and causing noise. I had an old water heater that was full of lime and especially at night I could hear sort of a percolating sound from hot spots in the lime (I assumed). When I replaced it, there was room for maybe five gallons of water in the 18 gallon tank. (It's a wonder how I ever got enough hot water for showers!)
It's really weird, it hasn't made a peep since I posted the original message. I have spooky feelings about this heater. I think it's an alien in disguise. Anyway the house is for sale and maybe I'll sell it before it decides to sing again. (Oh, please.)Tigger
