Generator vs welder/generator for power?
Warren | Posted in Energy, Heating & Insulation on July 28, 2005 08:27am
Welder generator in lieu of just a backup generator. Checked and a Generator unit with a B&S engine appears to sell for more in 10,000 watt configuration than a Mill*r BC 250. Also rated at 10,000 watts.  Why should I not buy a new “tool” ? Is there a problem I am missing?  Area is Central FL and generator back-up makes sense some times. The Kohl*r engine on the welder can run on gasoline or propane?
All I ever Needed to Know I learned in Kindergarten- Robt. Fulghum
  1. JohnSprung | Jul 29, 2005 01:10am | #1
    Maybe duty cycle?  The backup genny is designed for long hours of continuous output, the welder for short bursts?
    -- J.S.
    1. brownbagg | Jul 29, 2005 02:14am | #2
      not neccasary, some of the miller welders have 100% duty cycle and you see them running 10 hrs a day on jobsite for years. In years I mean ten to twenty.
  2. 4Lorn1 | Jul 29, 2005 04:55am | #3
    Good choice if you do a lot of welding on remote sites. But one you pay a premium for. Both in cost, several times what a simpler generator would cost, and in weight.
    A welder/generator is more efficient than a generator that would produce electricity which then would be converted to high amperage lower voltage at a separate welder. Less conversion loss.
    From the few I have seen most gen/welder sets are commercial duty and designed for sustained use for many years. This being expressed in the price.
    IBEWChuck | Jul 29, 2005 02:48pm | #4
    That's the exact set-up that I have . I have used the welder for back-up power for periods exceeding a week at a time, just stopping to check oil and fuel{I use gasoline}.Just remember to "exercise" your welder-generator occasionally to keep the battery charged. Also, if not hooked to propane, keep your fuel fresh. Some engines have a lower horsepower rating if operated on propane, reducing the available wattage at full load.
    1. Warren | Jul 29, 2005 05:40pm | #5
      Thanks for all that replied. I've decided to go with the Miller Bobcat 250 and put it on a trailer.  Unit weight is about 600 lbs.  The propane vs gasoline reduces the output by about 10 % so I think I'll stick with gasoline.
  4. Brilliant_Dummy | Oct 04, 2023 04:51pm | #6
    @Warren, how did that Miller Bobcat 250 work for you as a backup generator? I find myself considering the same thing & would value your experience.
