Getting rid of orange peel texture?
RoWSC | Posted in General Discussion on December 22, 2004 09:53am
My house was built four years ago by a creative home builder.  I live in a planned unit development so most of the neighborhoods are cookie cutter houses.  While our neighborhood has unique designs, the finish is all similar.  I want to backdate your  house so the finish is more in tune with the interior architecture.  Specifically, I want to replace the orange peel texture on the drywall with a smooth finish.  What is the best route?  I assume I can just skim it with sandpaper to make sure there are no high spots then trowel on a thin coat of plaster.  Can it be that simple?
Thanks,
Rich
  1. woodskill | Dec 22, 2004 10:08pm | #1
    Disclaimer:  I am a carpenter who has had a 15 year crash course in General Contracting.
    From my experience expect one heck of a mess, unless you section off areas and clean as you go.  I have gone the sand-spot-skim coat route and it has always turned out nice.  It can be time consuming, but cranking the heat up, get plenty of materials (compound, dustmasks, sand paper (medium to fine), plastic, blue tape, radio).  Beware of areas around moundings, cabinetry.  Build up around these areas will require a whole lot of unnecessary sanding.  Depending on you total surface area, you'll need a whole bunch of compound b/c your adding b/w 3/32 to 1/8 thickness in places.
    Good luck
    IMERC | Dec 22, 2004 10:26pm | #2
    Scrape...
    skim coat with thinned topping mix...
    sand...
    prime...
    do it all over again...
    WOW!!!   What a Ride!
    1. Mooney | Dec 25, 2004 07:19pm | #4
      Stripe the ceilings with yellow chalkline 10 inches apart to make this easy. The chaulk covers easy with paint.
      Id run a 10 inch float box set "tight " to skim an even 10 inch path that will plane over the bumps very nicely. Skip every 10 inches for the second application. Fill that when the first is dry with a 12 inch box which will over lap and feather running the box tight. Sponge mop sand the edges and no dust or edges. Use topping mud if available for it glides under a wet sponge. No dust and very slick work.
      You can do the same with 10 and 12 inch knifes working from a 12 inch pan. Just try to keep the angle of your knife the same to cover the same amount .
      Tim Mooney
        IMERC | Dec 26, 2004 07:33pm | #6
        I like yur way better....
        whatcha doing next week end????
        WOW!!!   What a Ride!
        1. Mooney | Dec 26, 2004 07:52pm | #7
          Got a new camera. How to get pics from "card " to infanveiw?
          LOL, U commin back through?
          Tim Mooney
          Edited 12/26/2004 11:53 am ET by Tim Mooney
  3. csnow | Dec 22, 2004 10:55pm | #3
    A skilled plasterer may be able to put on a nice veneer coat with no sanding.  Just a matter of if he can get enough 'tooth' on the substrate, perhaps with a bonding agent.
    Also consider the feasibility of putting a layer of 3/8 board over the whole thing.
  4. dinothecarpenter | Dec 25, 2004 08:40pm | #5
    51303.1
    The EZ way.
    YCF Dino
