GFI breaker
ovi | Posted in General Discussion on August 30, 2011 01:16am
Hello everyone,
I am installing a steam shower unit that requires a dedicated electrical circuit 30 amp, 220 v GFI protected.
since there s only need for two 110 phases ,and grounding line no neutral involved , my  question refers to what type of GFI breaker needs to be installed.As far as I know any GFI breaker either single  pole or double pole has a  set screw for neutral line, but in this situation there s no neutral coming from steam shower. Is a regular double pole GFI gonna work without connecting any neutral line ?
Any input appreciated and thanks in advance
  1. gfretwell | Aug 30, 2011 01:55am | #1
    Yes a 2 pole GFCI will work fine without a neutral load. Go ahead and connect the white wire from the breaker to the neutral bus and leave the neutral into the breaker empty if you are not running a neutral to the tub.
    You can't use 2 single pole units.
  2. DanH | Aug 30, 2011 07:43am | #2
    You need a double-pole (two single-poles will not do it).  Leave the neutral terminal unconnected (but connect the neutral pigtail, if your panel uses those).  Or, sometimes, it may be wise to go ahead and install cable with the extra wire, in case the unit is later replaced with one that needs a neutral.
How Trump's “Big Beautiful Bill” Will Affect the Inflation Reduction Act
The Big Beautiful Bill could do away with much of the Inflation Reduction Act, including the 25C, 25D and 45L tax credits.
  • A Postwar Comeback
  • Natural Simplicity
  • A Grand Rescue on the Coast
