GFI In bathroom
MSLiechty | Posted in General Discussion on March 24, 2009 02:07am
How is GFI grounded when retrofitted in an existing older home with no Ground. I’ve seen this many times where a new GFI is used in place of the original outlet.
It’s not really a GFI then is it?
ML
  1. gfretwell | Mar 24, 2009 02:18am | #1
    Yes the GFCI part still works
    BillHartmann | Mar 24, 2009 02:20am | #2
    A GFCI does not need a ground to work.
    It works by measure the difference in the current in the hot lead and the neutral and will trip if they differ by more than 5 ma.
    In fact GFCI's are specifically allow to proved for grounding style receptacles and downstream 3 prong receptacles without have a ground connection.
    They are suppose to have a label that says "No Equipment Ground", but that is rarely done.
    But many GFCI's do come with such labels.
    1. MSLiechty | Mar 24, 2009 03:13am | #4
      Thanks Bill Thats the answer I was looking for.ML
  3. caseyr | Mar 24, 2009 03:02am | #3
    As Bill indicated, GFCIs do not need a functional ground wire to work. However, if you really want a ground, for whatever reason, a separate ground wire can (usually) be fished and it was legal code when I installed some in my house. I assume it still is allowed. There are a number of ways in which the a separate ground wire can be run into an attic, a crawl space, or outside and then attached to a ground rod. Many books on DIY house wiring have sections describing the various tricks for this.
Installing Prefinished Cabinet Molding
Use these assembly techniques when installing crown risers and molding to minimize visible gaps and nail holes.
