Girder Overlap?
Hackinatit | Posted in Construction Techniques on February 10, 2006 02:18am
Glulams of 18″x1.75 were bought by client before talking to anyone.
I insisted he get an engineer to review these for his flush ceiling (under attic) girder application.
Engineer spec’d 2ea 11.25″ glulams bolted for the 20′ span.
Problem: the attic is low slope with 2×6 rafters that I don’t trust for the lift. I need to work beside a central chimney as well.
Question: Can I shorten these beams for easier lifts and splice/overlap as is done with sawn lumber?
Thanks!
Troy Sprout
Square, Level & Plumb Renovations
Edited 2/10/2006 3:04 am by Hackinatit
  1. Hackinatit | Feb 10, 2006 11:53am | #1
    Bumpity
    Troy Sprout
    Matt | Feb 10, 2006 02:54pm | #2
    Can you nail up some temp vertical bracing from the rafters to the floor?
    Or, you can rent a small portable lift at a rental supply.  I have seen them that are kind of like a small assemble on site forklift - no motor, just a hand crank winch to lift the load.  Maybe like a 500 or 1000 lb capacity which will easily lift your load.
    Personally I wouldn't splice the beam, but I work in new construction which presents more "ideal" conditions - if you wannna call it that - today I have to go work in a muddy parking lot and it's 24 degrees right now - figure out some grades for the entrance driveway "ramp" - oh well, at least the mud will be frozen for a while...
    Edited 2/10/2006 7:05 am ET by Matt
    BossHog | Feb 10, 2006 03:29pm | #3
    If you're talking about splicing the beam OVER A BEARING POINT, then yes.
    If you're talking about splicing it BETWEEN bearing points, then absolutely not.
    Did you ever wonder if the person in the puddle is real, and you're just a reflection of him?
    1. Hackinatit | Feb 10, 2006 04:57pm | #4
      Thanks, Boss....
      I thought the same, hoped for different.Troy Sprout
