Where do I find information on installing glass brick windows?
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
I have the units made up to size, they are grouted and banded. I install that unit in a jamb already set in the opening.
3'x4' is pretty darn heavy using full size block. Make sure you get a poundage estimate b/4 you order this way.
Here's some info.
Matching Sites | Page 1 of 18867View Image
Learn more about Matching Sites
Installing a Glass Block Window: Install Interior and Exterior Trim. From "Weekend Remodeling" episode WKR-112. advertisement ... http://www.diynetwork.com/diy/wi_installation/article/0,2037,DIY_14422_2277440,00.html
Installing a Glass Block Window: Prep Work, Remove Windowsill and Cut Out Interior Side Holes. From "Weekend Remodeling" episode WKR-112 ... http://www.diynetwork.com/diy/wi_installation/article/0,2037,DIY_14422_2277436,00.html [More results from http://www.diynetwork.com]
I have installed glass block windows in 100 year old houses with little harm to the ... Installing glass block panels in a basement window is very simple. ... http://www.askthebuilder.com/189_Glass_Block_Windows_-_Options_Galore_.shtml
How to Install Glass Block. Who says you can't live in a glass house? ... Window Tile by Gary D. Glass block look, beauty and privacy, and affordable for ... http://www.ehow.com/how_16760_install-glass-block.html
To add structural integrity to the glass-block window, install metal panel anchors and reinforcing wire along every other course. ... http://www.popularmechanics.com/home_improvement/home_improvement/1276626.html?page=3&c=y
Fill the joints along the sides and top of the glass-block windows with clear ... 9 Finish the job by installing trim around the perimeter of the window and ... http://www.popularmechanics.com/home_improvement/home_improvement/1276626.html?page=4&c=y
Q: I would like to replace a window in my house with glass block. ... I need a Prescreened Contractor for Window Installation and Repair ... http://doityourself.com/windows/windowglassblock.htm
With the preassembled glass block windows, another option is silicone grouting. ... I need a Prescreened Contractor for Window Installation and Repair ... http://doityourself.com/glass/glassblock.htm
Pittsburgh Corning LightWise Glass Block Windows Offer Easy Installation and New Look, Pittsburgh Corning Corp. http://news.thomasnet.com/fullstory/22521
Acrylic Glass Block Windows and Walls in different styles and colors ... beauty of glass block with the quick and easy installation of a standard window. ... http://www.cityglass.net/GlassBlock.html
Quittin' Time
Wow! THanks calvin!!! .......... I'll work through all your information.
Are you talking about interior or exterior windows? Or maybe for a shower/bath. Different methods for all three. I use a plac e called the Glass Block Shop with locations in Dallas and San Antonio. Depending on the application I will either buy individual block or have them build a unit with frame. As noted by the other person, pre-built windows get heavy in a hurry. Supporting them in the wall is not usually a problem, but transportation and lifting them into place can be a chore.
THanks Ed Hilton ........ I'll check out your sources. THey are for exterior windows.
The ones I get for exterior windows are factory made into a plastic/vinyl frame. it comes with a nailing fin and slips right into the opening like any other window. The down side is that the blocks are held in place with silicone caulk, which some people look down on ... they would much prefer mortared joints. If you decide to do it yourself, you need to buy special silicone or special mortar, both made specifically for glass block. The block supplier will have both. You can buy the block from HD-Lowes and they will have the silicone, but not usually the mortar. And they usually stock only one style of block, usually Decora. A block supplier will have 8-10 different styles. Someone mentioned 3 in vs 4 inch block ... the 4 inch is structural and must be used in certain applications.
At HD, we have a video from Pittsburgh Corning that walks you thru 3 different installs. Pay attention to whether you need 3" or 4" block---Big Difference!
THank you wango ... I have ordered the video. Appreciate the suggestion.
Nothing about install, but a "new" to the US brand of block is Vetro Arredo. (Google will bring up this site.) These are superb. The clarity of glass is far better then the Corning. And they come in colors!
Yeah, they do have some neat uses for glass block. I always wonder how much of a PITA a glass block shower wall would be to keep clean.
http://www.vetroarredo.com/vetroarredo/index.html
The reason so many people never get anywhere in life is because when opportunity knocks, they are out in the backyard looking for four-leaf clovers.-- Walter Percy Chrysler
I also have the units made to size, grouted and banded. Can't beat it. I seal the outside edges with white PL polyurethane window and door caulk/adhesive. It grips well, stays flexible, and it's paintable.
Billy
