Glass scratches
cloudbuster | Posted in General Discussion on June 19, 2008 04:07am
Hello:  I have a new entry door whose glass was scratched in two places, each approximately 2″ long.  You can feel the scratch with your fingernail.–Of course no one takes the blame for the scratches.
Question:  Any suggestions as to how to eliminate/minimize the scraches.  I talked to several glass shops and none are even willing to look at the scratches.  I believe they all would rather replace the glass.
The door is a factory prefinished mahogany door and the trim would be destroyed if  we had to replace the glass.
Cloudbuster
  1. 2Paul | Jun 19, 2008 04:22pm | #1
    Home Depot sells a frosted window film that would allow light through but hide the scratches, if you don't mind losing the clear glass view.  Also available in stained glass look.  I've used it in my bathroom and it really looks good.
  2. KenHill3 | Jun 19, 2008 05:52pm | #2
    Just FYI- You won 't be able to 'polish' out the scratches.
  3. USAnigel | Jun 19, 2008 07:25pm | #3
    Being as this is a door glass panel it will be tempered. This means odds on it will shatter if you try and polish out the scratches, this why they won't try to fix it. But if your feeling brave, get some glass polishing compound and have ago!
  4. sledgehammer | Jun 19, 2008 07:37pm | #4
    Cerium oxide will remove the scratches, and being tempered doesn't matter.
    You can polish to the point of distortion.
    Most door glass scratches are a result of diamond rings.
  5. reinvent | Jun 19, 2008 10:57pm | #5
    http://www.ipsglass.com/glass-polishing-kits.htm
    http://www.caswellplating.com/buffs/glass.htm
    Or if you want to spend the big bucks and start another side business:
    http://window-cleaning-supply.com/detail.aspx?ID=1330
    1. Kaya | Jun 19, 2008 11:42pm | #6
      If you can feel the scratch with your fingernail, don't waste your time trying to polish it out.
  6. woodway | Jun 20, 2008 12:29am | #7
    If amateur telescope makers can polish mirrors to a curve then you can polish out any depth of scratch. It may not be optically the same as the rest of the window but hey, that wavy feature you see when looking through the window is a sign that the glass is really old and it makes it worth more.
    1. KenHill3 | Jun 20, 2008 09:53am | #8
      To anyone who wants to try polishing out scratches in glass- hey, knock yourself out!
  7. IdahoDon | Jun 25, 2008 05:54am | #9
    I'd say get a glass polishing kit and have at it.  You won't need to completely polish the scratch out, just smooth it enough that it's not as noticable.
  8. User avater
    intrepidcat | Jun 25, 2008 06:30am | #10
    Try a professional autobody paint store in your area. Body shops buff glass all the time. It's common to get nicks in side windows fro grinding, welding ,etc. Sometimes windshields have to be buffed out.
    "Never pick a fight with an old man. If he can't beat you he will just kill you." Steinbeck
  9. RedfordHenry | Jun 25, 2008 06:32am | #11
    I tried to polish scratched glass once and wound up with a much larger, and far more obvious "frosted" patch.  I probably didn't rub it long enough with the proper sized grit, but my arm gave out long before the scratch was completely polished.  I'd suggest practicing on a piece of glass first before taking any abrasive pad to the window in the front door of my house.
  10. inperfectionist | Jun 25, 2008 01:20pm | #12
    Cloud,
    I was having lunch in a major metro area. At this deli was a fellow polishing out some scatched graffitti in the store front glass.
    He seemed pretty well all set up for the job. It did leave the glass optically different.
    Harry
  11. DanH | Jun 25, 2008 01:23pm | #13
    Check out the options at an auto parts place. There are preparations that will fill the scratches and minimize their appearance.
    It is an ironic habit of human beings to run faster when we have lost our way. --Rollo May
    1. shineglass | Mar 27, 2011 11:35pm | #14
      Scratched Glass
      I would be hesistant to try alot of this DIY stuff on the glass you are talking about; it may not be a bad idea to get an old piece of glass from a recycle center and practice these techniques on that glass first.
      1. calvin | Mar 28, 2011 06:56am | #15
        I see you have a business.
        Care to explain your methods and products?
        1. DanH | Mar 28, 2011 07:08am | #16
          Yeah, I notice his website doesn't care to explain anything.  Just "magic occurs, and then you pay me".  No hint as to how long the treatment lasts, etc.
          1. semar | Apr 01, 2011 08:13pm | #17
            glass scratches
            could it be done with the same stuff they use to repair windshield chips?
          2. DanH | Apr 01, 2011 08:43pm | #18
            No one knows, because his site doesn't tell you.  Could be beeswax rubbed into the scratches.
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
